Old 08-05-2022, 08:38 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Lost a bracket bolt- can someone tell me the thread pitch or PN
I had this irritating rattle and I tracked it down to a bolt, or more precisely the lack of one. It screws into the side of my 3RZ engine (passenger side), and it's a bit difficult to get replacements for since I have nothing to go off of.
Here is a link to the photo of the missing bolt if image breaks
1998 4runner 2.7 manual
Last edited by Pyral; 05-16-2023 at 02:37 AM. Reason: Maintaining photos (linkrot)
Pyral is offline   Reply With QuoteReply With Quote
Old 08-05-2022, 08:44 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Probably an 8 or 10mm with 1.25 pitch.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 08-05-2022, 09:34 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
And if not 1.25, then 1.5. Maybe a 12mm
I'd put money on it being a combination of those 4 details. I'd just go to a hardware store and snag a variety to check and see. Or similarly see if a nearby bolt fits in there for reference. Chances are there's another one around somewhere on the vehicle
Old 08-05-2022, 09:55 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Which part is that bolts to it? I can see the bolt threads into the engine block but is that plastic piece part of the air box?
Old 08-05-2022, 10:08 PM #5
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Its a bracket that holds the engine harness in place. It's probably the same specs used for the bolts that hold the airbox to the side of the engine.
Old 08-05-2022, 10:30 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Can you match up the bracket to the one that is missing on your bracket? As this is maybe the diagram that you are for.
WIRING & CLAMP. 1998 Toyota 4Runner Base 2.7L M/T | Toyota
Old 08-05-2022, 11:14 PM #7
davidch davidch is offline
davidch will become famous soon enough
The bolt is M8x15, 1.25 thread. I just pulled one off my '99 3rz; it's still warm in my hand.
The factory bolt has a flat washer that can't be separated - the washer was installed on the bare bolt and then the threads were rolled on - so just get a 15 or 16mm bolt and add your own washer. It's not a critical bolt so any old M8 bolt will do.
Revision: I found the part number: 91642-C0814. (from page 2 of the Wiring Clamp diagrams) So its length is 14mm. I had measured the bolt I took off in the standard way one measures a bolt's length, from the underside if the head. Apparently, Toyota measures bolts with affixed washers from the underside of that washer.
Lamentably, you may find that the aftermarket bolt has 13mm flats, whereas the factory item has 12.
As an aside, I've never had any luck finding M10x1.25 bolts in hardware stores or Loews or Home Depot. There are, in my experience, very few instances of M10x1.5 thread on Japanese-made vehicles, yet that's what's commonly retailed in the US. Ditto for M12.
DIN Metric Thread Pitch Chart (Coarse, Fine & Extra Fine) | The Fastener Resource Center
davidch is offline   Reply With QuoteReply With Quote
bolt , difficult , lost , replacements , side
Rear Shock Bolt size/pitch Okki 5th gen T4Rs 6 04-17-2024 02:16 PM
RCI bolt on slider help (frame thread pitch?) 4OYOTER 5th gen T4Rs 9 06-13-2017 01:41 PM
Side Frame Bolt Size/pitch Javelin 5th gen T4Rs 2 06-25-2014 12:41 PM
Rear frame bolt pitch Javelin 4th Gen T4Rs 2 06-26-2012 04:57 PM
cylinder head bolt thread pitch face2six Classic T4Rs 1 06-19-2007 07:39 AM
