Old 08-07-2022, 07:15 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral will become famous soon enough Pyral will become famous soon enough
Pyral's Avatar
Real Name: N/A
Squeaky Clutch Pedal- Not caused by the spring
When I put the clutch in or out, I can hear a creaking sound coming from outside the car. It's definitely not the typical clutch spring issue, you can hear it standing outside the car, and I already did the linear spring conversion.
It sounds a lot like a creaky old mattress on a honeymoon. I tried replacing the clutch fluid yesterday, and the fluid that came out was dark like coffee. Based off that, I suspect that either my clutch master or clutch slave cylinders is the source of the noise.
The thing is that I have no other problems with the clutch pedal, I never lose fluid and the pedal feels as it should. I'm not willing to spend what a new oem master cylinder costs if the only problem it's giving me is a noise. Is there anything else that could be causing my problem?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 08-07-2022, 07:50 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
This is what I do before posting on the forum. As the posts go back for 19 years.
I goto Google and search. For example:
site:toyota-4runner.org/3rd-gen-t4rs/ squeaking clutch pedal
Lots of information in those listed threads that will help you on your quest
Old 08-07-2022, 10:25 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
When you push the clutch pedal that pushes a rod into the master cylinder which sends fluid to the slave cylinder which pushes the throw out bearing arm which pushes the throw out bearing against the clutch pressure plate diaphragm which releases pressure clamping the clutch to the flywheel.
Your noise could be caused by any of the moving parts after the slave cylinder as well. Use a mechanic’s stethoscope or long screwdriver/prybar to try to narrow down where the noise is coming from while someone is pushing the clutch pedal in/out.
Old 08-08-2022, 01:03 AM #4
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
The eternal, never-solved clutch squeak mystery:
My 97 had that same dry creaking sound for the first few years after I bought it in 2013. It now seems to have vanished. Mine still had (and still has) the original clutch pedal spring. Early on in the saga, I put moly grease on the spring contact point on the pedal (where the plastic bushing always disintegrates), and did the same to the slave cylinder pushrod where it contacts the dimple in the throwout bearing arm. But the creaking noise didn't go away immediately. It was months or maybe a year later that I realized that the clutch action had stopped squeaking.
I concluded that it was coming from inside the bellhousing, and there was no way I was going to go through the expense of taking that apart until the truck needed a clutch job.
pluton is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 06:23 AM #5
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has much to be proud of JZiggy has much to be proud of JZiggy has much to be proud of JZiggy has much to be proud of JZiggy has much to be proud of JZiggy has much to be proud of JZiggy has much to be proud of JZiggy has much to be proud of JZiggy has much to be proud of JZiggy has much to be proud of
JZiggy's Avatar
It’s common for the contact point between the slave cylinder and the pivot arm to get dry since it’s not protected from weather. Pull the slave cylinder, apply some tacky moly grease, and reinstall. I have to do this every couple of years.
JZiggy is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 09:28 AM #6
rglsr rglsr is offline
rglsr is on a distinguished road
Try this, the clutch fork has several metal to metal contact points, my Tacoma had a squeak/creak like this (faint and intermittent). Turned out to be the clutch fork internal to the bellhousing. You need to get under the car with someone operating clutch to pin point it.
rglsr is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 11:57 AM #7
Real Name: Patrick
Real Name: Patrick
Since I'm not the one with the issue I'll quote you two together to make sure the OP sees this. I feel like a matchmaker
Old 08-08-2022, 06:32 PM #8
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Today I went under and had someone push the pedal in, I can confidently rule out the master cylinder. It's either from the slave cylinder or where it enters the transmission.
It could be the clutch fork in the internals, it sounds just like this (no rattle like he shows later on). I'll see if I can pull back the boot and spray grease inside.
Edit: I took the boot off, wiped down some of the moving parts and sprayed a bunch of lithium grease on (as shown in video I linked). The noise has completely gone away, success!
Old 08-08-2022, 10:27 PM #9
Real Name: Patrick
Real Name: Patrick
I love a cheap fix! I’m glad you found what it was and fixed it
Old 08-09-2022, 08:38 AM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Glad it's fixed. Good troubleshooting to narrow down the problematic issue. .
clutch , fluid , noise , pedal , spring
Clutch pedal spring delete/mod octanejunkie 3rd gen T4Rs 6 11-04-2022 11:13 PM
Squeaky clutch pedal Billaban 3rd gen T4Rs 15 02-28-2020 11:50 PM
Squeaky Clutch Pedal on 1997 4 Runner Pete 2009 3rd gen T4Rs 7 11-15-2016 09:23 PM
Squeaky Clutch Pedal seoulstice 3rd gen T4Rs 2 11-03-2016 12:38 AM
squeaky Clutch spring MTDewX8 3rd gen T4Rs 6 01-26-2011 09:12 PM
