08-08-2022, 05:39 PM
front turn signal with factory fogs
Hi 4Runner enthusiasts,
I'm struggling to find a front (in the bumper) RH turn signal part # for a 1998 Limited with Factory fog lights. All the searches that I come up with carry the turn signal without fogs. The lenses on the turn signals are clear (with fog) v. amber on the non-fogs. Any help would be greatly appreciated.
08-08-2022, 06:43 PM
Real Name: Blair
Real Name: Blair
I have a 2000 LTD with (separate, round) fogs. Not sure how that affects the turn signal's lens color (many people seem to buy clear lenses on the aftermarket) but a picture would help. I ask because I may have a set of spares after a bumper swap soon....
258K - Y2K/E - Clock still works
08-08-2022, 09:23 PM
2000 Hilux Surf SSR-X Millennium Silver 3RZ
08-09-2022, 03:24 PM
It's hard to tell but it doesn't seem like the right shape...
08-09-2022, 05:06 PM
I'm starting to think someone replaced the 1998 factory turn signal with a 99-2002 fog light/turn signal.
08-09-2022, 05:09 PM
The fog light is not attached to the turn signal light at all. They are 2 separate lights.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
08-09-2022, 07:45 PM
that is correct.
08-10-2022, 04:36 AM
FOG LAMP. Toyota 4Runner | Toyota
Is this helpful?
08-10-2022, 01:26 PM
That picture is from a '99+ front bumper. You need '99-'01 front turn signals.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
08-11-2022, 10:39 AM
This is what I used for my sept 98' - 99' model, you would need the orange bulb though as it doesn't have the OEM orange reflector.
IPCW CWB-200B Clear Front Bumper Light - Pair, Bumpers & Bumper Accessories - Amazon Canada
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
