Old 08-12-2022, 01:44 PM #1
Auce Auce is offline
Auce is on a distinguished road
Spray painting a reciver hitch, installed.
I'm not terribly great at spray painting to make it look smooth and even. The receiver is on and I'm not taking it off so I'll have to paint it as is. There is rust and pitting on the sides of the receiver, not so much on the front that you're always looking at. I plan to cover the rust holes with a layer/patch of JB Fiberweld. One friend suggested filling it with spray foam, but that's looks like it can be a mess. When it comes to spray paint itself, what's the best method to not have it look all globby and messy? Short strokes from a distance? Just gently hit the spray button and go over it easy? I figured less is more, if I don't apply enough paint I can always add more rather than over doint it. I'll post some before and after when all is said and done. Thanks for any input. For some reason my pics are not coming through.
Auce is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 02:49 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Is your hitch full of rusted through holes or just pits?
I mostly clean the steel as good as i can then put a rust inhibitor on the steel. Like expoxy primer or corroseal etc. Then a coat of kb seal or equivalent with a uv protectant top coat on.
If it's rusted through. You may want to weld the holes shut and not use it at all for towing. Unless you can really weld good and can repair it properly to get all its strength back.
Another option is to super clean it a coat of rust inhibitor expoxy primer then a layer of fiberglass resin then paint it. The fiberglass resin gives it a layer water and oxygen can't get through.
However, how long it lasts depends on how good of a job you dud preeping the metal.
On spray paint light even coats. With your spray nozzle perpendicular to the surface I believe.
I mostly just brush or foam brush the paint on myself.
Old 08-12-2022, 03:52 PM #3
I have no intentions of towing anything, and yes one side is rusted through. I just want to band-aid this eye sore.
Imgur: The magic of the Internet
I'd add more details to your answer Brillo but Im' driving.
I have no means or tools to weld that's why I got the JB fiber glass kit. I was told I can lay it over the hole, let it cure and paint over it. I know it wont last forever. I'd just like it to look as clean as possible, Thank you all again.
Old 08-12-2022, 04:24 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Very common the passenger side is Rot the driver side is the drain hole..
If band aide fixing. You can use fiberglass cloth and resin like I did on my hatch on my build profile.
My one hitch was 10x worse then that when we fixed it with steel.
I could fix that but your too far away.. Another rust belt fellow. K feel your pain.
Old 08-12-2022, 04:26 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes you can cover that hole and paint over.. I give it a few coats of Glass then paint..
Old 08-12-2022, 04:30 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Unless you want to drive it up here and I will weld that hole shut for you and grind it back down. Once that's done unless the bottom is rotted out of the hitch it would be solid again and even be functional.
Old 08-12-2022, 05:15 PM #7
Why not take it off and leave it off? And while you are at it, hit that frame and everything underneath with something to hold off the rest of the frame rusting more than it has (some oil based product, etc.).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-12-2022, 05:26 PM #8
I appreciate that offer but western PA is probably a stretch for me.
Old 08-12-2022, 05:31 PM #9
I thought about that Charlie, the backup cam is drilled into the receiver and some wires are zip tied onto it as well. I don't want to sound lazy but I don't want to tackle all of that in this heat. I have some spray foam I thought about doing the under carriage with when it gets a little cooler out.
Old 08-12-2022, 05:33 PM #10
Luckily the bottom hitch area only has very small surface rust. Not rotted out at all.
Old 08-12-2022, 09:39 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Good the bottom is still solid.. Yes I am quite a bit away from new jersey.
Old 08-12-2022, 10:14 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If you use spray foam on steel it rots a lot faster. That foam holds moisture along with water and salt. You can do as you wish though its your rig.
I personally will not use spray foam. The PO did the rockers in spray foam in Tetanus 1 and there was nothing left when I cut the old metal out and rebuilt the rockers on that rig.
Old 08-12-2022, 11:34 PM #13
Thanks again Brillo, no foam will be used what so ever. I'll actually return it.
Brillo, I don't want to be a pain or nag in any way, but I'd like to do this correctly the first time. Can you give me any tips on using the JB Fiberglass kit? Would you do both sides of the receiver or just the rotted part?
I'm hoping to find a video that someone did on a receiver or something similar so I have a better understanding before I start the process.
I wire wheeled all the rust I could tonight, it's not flat like a grinder would do but I did my best. I took some heavy grit and gave it one more rub to maybe help the Fiber adhere to it.
Old 08-13-2022, 11:12 AM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well the correct way would be replace remove or weld the hitch .
It's best to leave the drain hole on the driver side open.
So you can shot some fluid film oil or transmission fluid in the inside of the hitch.
Get the metal a clean a possible. Then coat the hole the your fiberglass patch. Let let as dry. Give it a 2nd Coat. Lightly sand and paint it.
Hope for the best.
Old 08-13-2022, 12:19 PM #15
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I feel like removing the hitch would be a lot easier than trying to repair and paint it.
paint , painting , receiver , rust , spray
Spray Down engine bay with Silicone Lubricant Spray Knight-Errant 5th gen T4Rs 15 01-02-2016 01:57 AM
Spray painting exhaust tip BPo001 4th Gen T4Rs 3 03-28-2013 10:12 AM
Spray painting Red' Surf89 Classic T4Rs 1 03-15-2012 06:39 PM
Hidden Hitch vs Factory Installed Hitch, what's the diff? morphius909 4th Gen T4Rs 5 03-11-2008 12:16 AM
