Old 08-15-2022, 09:38 AM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by danwyl View Post
When I installed my 199mm calipers I found that my stock 3-spoke wheels wouldn't clear the calipers, but I'm almost 100% certain I tested the steel spare and it cleared properly FWIW.
Hmm. Where they 15 or 16 inch?
Old 08-15-2022, 10:14 AM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I can tell you these fit. As they have 199 mm calipers[TBU] under them. Maybe some do not. As I am not certain
Old 08-17-2022, 11:04 PM #18
danwyl danwyl is offline
danwyl is on a distinguished road
They were 16's. It seemed like it barely didn't clear the caliper, so I wonder if it was a caliper casting thing. I could have probably shaved the caliper slightly to get it to clear, but I decided to just pick up a nice set of 5-stars instead
danwyl is offline   Reply With QuoteReply With Quote
Old 08-17-2022, 11:17 PM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ok. So this confirms some r16 rims will not fit the 199mm TBU rotors. Good to know.
Old 08-19-2022, 02:00 AM #20
bgrump's Avatar
bgrump bgrump is offline
Real Name: Bryan
bgrump is on a distinguished road
bgrump's Avatar
Real Name: Bryan
I can confirm that as well lol. I have slowly been rebuilding my whole front end. I originally bought 4runner rotors and pads and had no plans to do the upgrade because I didn't want to buy new calipers. I found out that one of my calipers had a seized pin and it was ruined. At that point I figured why not if I needed new calipers. I went with the 199mm because I read it was more plug and play.
I finally got the brakes in a short while ago. I haven't had anyone around to help me bleed them so I hadn't tried to put the tires back on. Last night I was browsing the forums and I came across this thread. I knew I was screwed. I went out to the garage and yep the caliper is too big for the r16 wheels.
Lucky I bought some F5s a while ago. They will go on when I get new tires. But for now I am still a ways off from getting my rig back on the road and am not ready for tires. I just ordered some 1/4" spacers and am hoping that will allow me to get the tires back on so I can start working on the rear.
bgrump is offline   Reply With QuoteReply With Quote
Old 08-19-2022, 01:26 PM #21
I got a used late 1st gen Tacoma / early 1st gen Tundra 16" aluminum wheel to use as my spare. I figure the wheel that was designed to fit over Tundra brakes would fit over Tundra brakes. No rusting under the truck either!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
brake , calipers , fit , tundra , upgrade
Tundra Brake Upgrade Wheel Advice Thomas_Magnum_'98 3rd gen T4Rs 15 10-27-2016 11:30 AM
Tundra Brake upgrade, wheel clearance redneckj 3rd gen T4Rs 1 03-14-2016 12:37 PM
Tundra Brake Upgrade and wheel size? Southtwnr 3rd gen T4Rs 2 12-04-2014 04:34 PM
Tundra Brake Upgrade Wheel Fitment Question AK_Runner 3rd gen T4Rs 1 09-06-2013 07:14 PM
Quick Tundra Brake Upgrade Wheel Question GoodieKev 3rd gen T4Rs 1 07-21-2012 08:40 PM
