Originally Posted by Andrea
really appreciate the well detailed response... even though am not the OP, hopefully brillo_76 will leave a response here, looking forward to hearing what he says
The 199 mm rotors are the same stock rotors except the rotors are wider then stock and the calipers are as close as you can get stock oem Size.
The late model and sport rims will fit. R16. My spares are aluminum and I have try a steel r16. I suspect they as steel rims are alot thinner then the aluminum rims.
Correction: 8/14/22
The early rims will fit. These rims will not fix my 2009 Tocuma but the 01 and 02 sport rims will
I truly expect the steel rim to fit. However, I never tried.
3 bears is correct I do the 199 mm calipers and wide rotor to solve the rotor warpage issues.
I actually rebuild the calipers from the junk yard with new o rings speed bleeders. Even sand blast them as I live in the rust belt.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
