Old 08-13-2022, 12:37 PM #1
tekstrand tekstrand is offline
Real Name: Tommy
tekstrand is on a distinguished road
Real Name: Tommy
Unhappy ABS broken after broken ball joint/frontend rebuild
Summary
Front right ball joint broke while driving at low speed. Replaced ball joint, tie rod, sway bar, brake line, abs sensor. Vehicle now triggers ABS when coming to a stop around 5mph even if it is not slipping. Below are the notes from my friend who has helped me work on everything. We're not sure what to do next. Do any of you have ideas?
Notes from mechanic
  • The Anti-Lock Brake System is engaging the right front wheel right before the vehicle comes to a complete stop. Codes in ABS module for right front wheel speed sensor.
  • The right front wheel speed sensor is reading that the right front wheel is not turning the same speed as the other three wheels. This causes the ABS to engage because it thinks the wheel is sliding. In reality it’s not, but it’s reading that it is.
  • Codes were pulled from ABS module- right front wheel speed sensor (I do not have the exact code number in my notes, but should still be present in the module when powered up). First thought we had a faulty Speed sensor.
  • Performed ohm check of sensor and its wiring. No issue found. Ordered and installed another front right sensor- same condition.
  • Thought that possibly the cv axle may have had a different number of teeth on the reluctor wheel- tooth count was checked twice. We counted both sides and they are the same number. Checked for damage on the axle- none found.
  • Replaced CV axle again with different brand in case the reluctor wheel was not reading correctly - still same condition.
  • Remove wiring terminal and perform ohm check of wiring from ABS module to sensor. No short to ground or disconnected wiring found.
  • Check distance of sensor to reluctor wheel. Same on both sides.
  • Check wheel size and pressure - sizes are the same- air pressure correct.
  • Next step would be to check the pressures in the brake calipers to see if they are applying the same pressure to each side. If that value is correct will need to research other possibilities This has now been completed and the pressure is the same
1999 SR5 4wd
tekstrand is offline   Reply With QuoteReply With Quote
Old 08-13-2022, 01:36 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What type of abs cable did you use to replace it? Maybe it's not 100% compatible. As you really covered the bases on this one.
Old 08-15-2022, 02:30 PM #3
Real Name: Tommy
Real Name: Tommy
We've replaced it 3 times now, ordered from WorldPac. Not sure on the exact brand.
1999 SR5 4wd
Old 08-15-2022, 04:19 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I've never heard of WorldPac before. Have you tried switching the front wheel speed sensors and seeing if the problem follows the sensor? Toyota's are sometimes very picky about certain parts being OEM to function correctly.
Old 08-15-2022, 05:35 PM #5
Real Name: Tommy
Real Name: Tommy
WorldPac is just a wholesale distributor for auto shops. It's was OEM. WORLDPAC - The Right Part at the Right Time(R)
1999 SR5 4wd
Old 08-15-2022, 06:09 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh an oe supplier. Ok. That makes more sense.
Old 08-15-2022, 06:56 PM #7
Real Name: Patrick
Real Name: Patrick
So it showed up in Toyota packaging?
Old 08-15-2022, 08:59 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I would try a known good Oem used one to see if your abs issue goes away.
Old 08-16-2022, 09:08 AM #9
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
What year truck is this? The ABS reluctor ring is not on the CV on a 3rd gen, it's sandwiched in with the wheel bearing.
Did you inspect the wheel bearing for run out?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 08-16-2022, 05:20 PM #10
Makitso Makitso is offline
Makitso is on a distinguished road
Are both front tires the same size?
2000 4Runner Limited w/TRD Supercharger
And E-Locker
Makitso is offline   Reply With QuoteReply With Quote
Old 08-16-2022, 05:22 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Both very good thoughts..
abs , front , sensor , speed , wheel
Upper Ball Joint/Lower ball joint replacement Tigerfan86 4th Gen T4Rs 1 03-03-2020 03:10 PM
Leaking Upper Ball Joint - Replace UCA's or Just the Ball Joint tannerk15 4th Gen T4Rs 4 03-28-2017 08:53 AM
Leaking CV Joint or Ball Joint?? Hard to Tell - Pics Inside 4WDFTW 4th Gen T4Rs 21 11-06-2014 05:46 PM
Broken Lower Ball Joint Speedy Gomez Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-25-2014 10:19 AM
ARB broken, mud and lots of broken parts sibanez 4th Gen T4Rs 14 08-02-2006 06:59 PM
