Old 08-19-2022, 07:19 AM #1
Calloway Calloway is offline
Calloway is on a distinguished road
Fixable?
Looks like my rear passenger control arm link mount that rusted off. Do you think this can be welded back on?
Fixable?-pxl_20220818_144003736-jpg
Calloway is offline   Reply With QuoteReply With Quote
Old 08-19-2022, 07:58 AM #2
tgreenwood75 tgreenwood75 is offline
tgreenwood75 is on a distinguished road
Definitely fixable, but whether it is worth it will be a question that depends on the rest of the truck. How is the frame in general? Seeing this bracket and the third member, there may be too much rust all around to justify fixing this. In other words, you may be able to have a welder replace this bracket but you will be constantly 'firefighting' and unable to get ahead of the rust in other structural areas.
In terms of fixing this, the bracket itself is a simple one to replicate, but you'll need to break out a hammer, wire wheel, etc to ensure that the crossmember/tube that it attaches to is solid still, these tubes have fairly thin walls and trap sand/moisture/salt. They can be sleeved from the inside, but again you will need an idea of what this will cost and whether the other areas of the frame are solid enough to justify the repair.
Sorry to hear about the bracket failure and best of luck with the repair, I know that having a rusty frame is no fun sometimes! Almost anything is repairable (ask @brillo_76 ) but if you'll be paying someone else to do the work there always has to be a line in the sand after which it isn't practical.
tgreenwood75 is offline   Reply With QuoteReply With Quote
Old 08-19-2022, 10:46 AM #3
Thanks tgreenwood75. The car resides in NY so I know it has def been exposed to salt. I was planning to to provide some frame protection to help minimize the rust damage.
The truck has 187k miles on it so I think it has a lot of life left. I am the 2nd owner and absolutely love the truck. The rest of the frame seems fine but again I haven' checked the inside to see how much damage the rust has already done.
Old 08-19-2022, 08:42 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes. I have fixed worse. It can be fixed. The crucial thing is to get that or a new one aligned properly again. I slide steel pipe through the upper crossmember pipe and weld that in so you have good metal to weld to weld to. As your crossmember pipe would be rotted to nothing on that area.
I actually even rebuilt rusted off sections of those coil plates. You can see lots of my projects in my build thread.
Old 08-20-2022, 02:49 PM #5
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
U every think about what type of project build u'd b making if u weren't always having to repair rust buckets.....
clearock is offline   Reply With QuoteReply With Quote
Old 08-20-2022, 03:03 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I just like to tinker with them. In the rust belt, It's cheaper to run rust buckets. Alot of practice I get fixing them and I only started fixing frames to learn how to weld better. Then I got carried away.
I have enough yet for several more years. Then I see what's next.
Old 08-20-2022, 03:58 PM #7
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Before he started fixing frames we would just hang out in the garage drinking popov and smoking pinners
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 08-20-2022, 04:31 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Where do you come up with these things.. lol.. Randy likes to keep things interesting.
Old 08-21-2022, 07:28 PM #9
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
You can get frame repair pieces here (probably other places too), which might be helpful.
4-Runner 1996-2002 3rd Gen Archives - autorust.com
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 08-22-2022, 09:19 AM #10
Thanks everyone for your replies and help!
Will llook at this also but the first place I called seemed very doubtful saying it would be very weak (but I guess thats why Brillo recommended putting in a pipe).
Is an axle housing swap possible or is that overkill? I want to keep this truck as long as possible.
Thanks!
Old 08-22-2022, 09:59 AM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Thanks!
I have one that has an axle swapped. My rear axle housing was really starting to rot up.
Very few places will deal in frane repair. This is why I learned to do it myself.
As they don't want the liability. Which is understandable.
Paying people to do it sometimes can get very costly.
How that one is rotted. It maybe easier to get a replacement new bracket and weld it to the pipe insert.
Luckily, its on the passenger side away from the gas tank.
Old 08-22-2022, 01:13 PM #12
Thanks Brillo for your advice and spending the time to find the replacement perch I need to have the welder put on!!! You rock!
Old 08-22-2022, 07:57 PM #13
I had a failure like that on mine when I first got it, but over by the gas tank, I didn’t weld at the time so I had a guy I know make a new bracket and weld it in for like $150. Usually frame repair of any sort is several times more than that because of how much of a liability it is.
The good news is if you’re dedicated you can keep all but the rustiest shitbox on the road for a long time, once you get that welded up get the rust scale off the frame, hit it with a rust converter like Ospho then give it a nice coating inside and out with fluid film, oil, grease, etc
Old 08-22-2022, 09:07 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Plus soon I be able to show what happens when you just weld plates over things. As my first one I threw together in 2015. My one was experimental repairs. Before I switched to internal frame plating.
Old 09-01-2022, 10:55 AM #15
Just wanted to close this out. Was able to find a welder and he was able to put a new part on. Now time to tackle the frame rust!
Fixable?-image-1-jpg
back , fixable , mount , rusted , welded
Frame rot - fixable? WRWhit93 3rd gen T4Rs 1 09-23-2016 07:40 PM
Fixable? Calloway 3rd gen T4Rs 29 02-23-2015 11:36 AM
Pinhole in CV Boot...fixable? gman72 4th Gen T4Rs 1 07-05-2013 10:45 PM
Is this fixable??? andyk5 4th Gen T4Rs 12 08-06-2012 06:46 PM
Is this fixable? SCRunner12 3rd gen T4Rs 8 04-11-2011 04:27 PM
