Old 08-19-2022, 02:44 PM #1
99SC4Runner's Avatar
99SC4Runner 99SC4Runner is offline
99SC4Runner is on a distinguished road
Auxito LED headlight bulbs
I got a set of LED headlight bulbs for my 97 4Runner from our forum sponsor Auxito - AUXITO(R) Car LED Lights | LED Forward, Interior & Exterior Lighting
The headlight bulbs were packaged great and look to be made from high quality materials.
Installation was simple and straightforward. I didn't have to remove anything to install them.
They had to send me the decoders because the only issue I had was the high beam indicator was not coming on in the instrument cluster.
I still need to readjust my headlights, but these LED bulbs are bright with no flicker or other issues so far.
The first couple pics are my stock halogen bulbs.
Installation of bulbs without removing the battery
Low beams
High beams
99 4Runner Ltd 4x4, 3.4 V6, Gen 1 TRD supercharger, URD fuel kit w/ 2.2 pulley, IPT VB trans upgrade, Hayden 1679 tranny cooler, Dual Exhaust from muffler back, Deckplate w/Amsoil filter, Air Raid Intake, Lotek dual gauge pod with Boost and Tranny temp gauges, TRD Tundra Front Coil Lift w/Tundra Bilsteins, OME 891's rear with Monroe air shocks, ARB Sahara front bumper w/IPT fogs, MM 9500# winch, 285x75R16's Maxxis Bighorn Radials on Ivan Stewart TRD wheels, and front Clear corners. - SOLD
99SC4Runner is offline   Reply With QuoteReply With Quote
Old 08-19-2022, 03:44 PM #2
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
You’ll have to follow up after a period of time to let us know how they’re doing, any issues to report and so on. I ran Beamtech LED’s for about 2~ years and they’d eventually burn halfway out. Then I would reach out to the company to file a warranty claim, follow the instructions given and they’d send me a new bulb. Wash, rinse, repeat for two years.
I finally said enough is enough. I just bought some cheap Hella bulbs that lasted about 5 or 6 months. Then last month I bought some Sylvania halogen bulbs that have been working flawlessly ever since installation.
The thing for me with LEDs in our trucks is that they aren’t made for our housings and as a result, can and likely will blind oncoming drivers. I don’t need to risk my family’s safety or my own because someone else can’t see due to my headlights. But hopefully you’ll have luck with them. Not to mention, they are illegal in my state.
Old 08-19-2022, 09:47 PM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I've run LED headlights for several years and have never had anyone flash me thinking I have high beams on.
Good LEDS replicate halogens reflective properties so they use the same projection, so have no blinding affects.
The Plus is how much brighter and further down the road they project, without blinding others. Luck all.
Old 12-06-2022, 04:28 PM #4
CLeeJ CLeeJ is offline
CLeeJ is on a distinguished road
@jgue467 , I'm looking for some LEDs for my 2000, what brand are you running, and do you have any recommendations? @99SC4Runner , are you still happy with the Auxito LEDs?
CLeeJ is offline   Reply With QuoteReply With Quote
Old 12-06-2022, 04:34 PM #5
Yes, I like them A LOT! They are really bright with great beam pattern. I don't get flashed from oncoming traffic either.
Old 12-06-2022, 08:04 PM #6
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I did. I literally had to spin the bulbs till they were adjusted right. They were so bad it took me 30 minutes to adjust them.
I just put the newer style headlights in and solved that issues.
Mine were from super bright leds bulbs though.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 07-08-2023, 09:28 AM #7
DWilliam DWilliam is offline
DWilliam is on a distinguished road
Low beams
High beams
My search for headlight bulbs led me to your post. Still liking them? Is the canbus adapter they sell on their site what you used in your installation? Easy plug and play?
DWilliam is offline   Reply With QuoteReply With Quote
Old 09-26-2023, 06:50 PM #8
I'm still liking them. The Can Bus adapter works and it was basically a plug and play upgrade.
Old 09-28-2023, 03:26 PM #9
zdale zdale is offline
zdale is on a distinguished road
So does your High beam indicator work now? I have tried a half dozen different encoders to get my High beam indicator to work and have not been successful.
Every year for inspection I have to put in One halogen bulb to get it to pass. As it is part of the inspection for it to work.
zdale is offline   Reply With QuoteReply With Quote
Old 09-29-2023, 08:09 AM #10
Put in a headlight harness that bypasses the factory switched negative. The high beam indicator will work through the relay coil.
Old 10-02-2023, 06:10 PM #11
The high beam indicator runs through the low beam filament of the bulb. Without a load (relay coil isn't enough), it won't turn on - and often the high/low switching will be affected. Just get load resistors on there, plug it into the passenger side stock harness while the driver's side runs an aftermarket harness.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-03-2023, 06:26 AM #12
With the harness I have the high beam indicator works properly. It’s not as bright as it would be with a 1ohm filament but it’s bright enough to see in daylight.
Old 10-03-2023, 12:01 PM #13
maxthebird maxthebird is offline
maxthebird is on a distinguished road
If you buy the Auxito LED's and your high beam indicator light doesn't work, they will send you a pair of load resistors for free. Just email them. You only need to install one. I've had this setup for about a year and it works beautifully.
maxthebird is offline   Reply With QuoteReply With Quote
bulbs , headlight , high , installation , led
Review: AUXITO Q16 9005 high beam bulbs jdm-v35 5th gen T4Rs 7 03-19-2022 05:52 PM
Cooperation Invitation From Auxito Auto LED Light Bulbs sleepydad 3rd gen T4Rs 9 02-26-2022 07:30 PM
New Headlight Bulbs (Please help) bluduk15 4th Gen T4Rs 12 03-01-2008 09:04 AM
06-07 Headlight Bulbs VQD83 4th Gen T4Rs 9 11-07-2006 11:59 AM
