01-15-2011, 01:29 AM
Real Name: Sean
Real Name: Sean
Removed Stock Radio - Now It Doesn't Work!!
Hi guys I'm new to this forum - this is my first post! But anyways I'm really in need of some advice. I was planning on taking my factory radio out of my 1997 4runner and putting an aftermarket jvc deck in. I found out I had the wrong wiring harness for the 4runner and long story short, decided to just put the stock radio back in. When I connected everything and put everything back, I turned on the car and the factory headunit didnt work. It still won't work even after turning the car on and off several times. Can someone please give me some advice on how to get this working again. I think I just need to reset something to get it working again. I'm leaving to go on a 15 hour trip back to Colorado tomorrow so I'd like to have radio. I would screw this up right before I'm about to leave !! Thanks!!
01-15-2011, 02:04 AM
hmmmm? have you checked your fuses? check the panel inside the truck there is one in there that contols the radio. I cant remember exactly which one though
01 SR5 SPORT
Many mods done, Many more to come
Build Thread
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
01-15-2011, 12:49 PM
Real Name: Sean
Real Name: Sean
Yeah we checked to see if there was a blown fuse but the radio fuse was okay. We thought that might reset some settings too but it just didnt work. Any other ideas? I''m down to the last minute
01-15-2011, 02:34 PM
wow thats just crazy! umm... there may be some other fuses in that panel inside the cabin that have something to do with it, i would check all of them, I remember when my keys were locked in the ignition and the shifter was locked as well i started pulling fuses and one of them freed eververything plus disabled the radio, other than that all i can think of is a connection from your stock amp may be un connected?
01 SR5 SPORT
Build Thread
01-15-2011, 03:47 PM
Almost all car audio systems have TWO power sources: a full-time 12V (fed by the dome light circuit on 3rd gen stock wiring) and an ignition-on main power )fed by the radio fuse). If I were doing this, I'd take a probe and test the harness for power at both circuits (main power with key on). I don't remember the stock color codes, (it's been 11 years) but the on-line wiring manual will tell you which ones to check. Then go from there.
My Backyard Frame Swap
01-15-2011, 03:50 PM
Real Name: Sean
Real Name: Sean
Originally Posted by bootown
Gonna sound really stupid but you did remember to plug it back in right? I've pulled decks out of 3rd gens many, many times and have never blown a fuse or had any kind of problem. Positive you didn't just screw it back in and forget about the connector (amp and deck)? Don't take it as in insult, there just aren't that many things that could have gone wrong and you already ruled out fuses.
That's really the only thing I can think of. I know I connected the main connection that gives the deck power because the cd part lights up when I turn the headlights on. But I'm going to go back and check the connections today before I leave and recheck the fuses like TRD said and hopefully that fixes it. It shouldn't be too complicated - it's a pretty straight forward process.
01-15-2011, 04:03 PM
Real Name: Sean
Real Name: Sean
If I had a day to work on it I would do this but I'm gonna have like an hour or so to get this figured out before I leave today and don't wanna mess anything else up trying to fix it. If I can't figure it out before I leave I'll try this once I get some more time to work on it.
01-15-2011, 05:02 PM
d
try to disconnet the neg battery ter. for about 5 mins that will reset the computer system, that or a fuse, or the plug not in all the way, or a wire not hooked up right i have put a numbers of headhunts in and have never had that problem check the fuse under the hood
01-15-2011, 05:09 PM
The 97-98's don't have any sort of fancy computer system that controls the headunit. It's just a normal wiring harness. Did you remember to plug in the antenna? Did you remove the factory amp when you tried to put in the other head unit? Just think really close and make sure you did all the steps. I've taken my factory head unit out several times and never had any trouble once I plugged it back in.
I'd make sure the harness doesn't have any loose pins or anything. The advice to reset it by unplugging the negative terminal is a good idea, too.
2019 SR5 Premium 4x4 - Black - ReadyLift 3/2 - TRD Pro rims - 275/70R17's
Previous: 98 SR5 4x4, 05 SR5 4x4, 98 SR5 4x4
01-19-2011, 08:20 PM
Real Name: Sean
Real Name: Sean
Yeah I double checked everything again and I can't find anything I'm missing except there was a spot for a plug in right next to the antenna plug. IDK what it could be cause I dont remember taking anything out of that and I can't find anything to go in that slot. But I disconnected all of the fuses in the fuse box under the drivers knee section. Didn't do anything. I can try disconnecting the negative battery terminal but isnt that pretty much what taking the fuse out is doing? Stopping the circuit from being closed?
01-19-2011, 08:37 PM
i dont know about all the other stuff, but the plug next to the antenna plug is like having 2 antennas, when i installed my kenwood from stock, i obviously didnt have the 2 holes, so i left the smaller one out (the one underneath the antenna) and now i dont have AM radio(not that i am complaining. haha). so im guessing thats what it is. but i could be wrong. just my thoughts.
2004 4Runner SR5 V6 2wd
My Build/Mod/Repair Thread
My Beauty Shots
01-19-2011, 08:40 PM
taking the neg terminal off will reset your computer, the fuses actually just make it so you dont blow anything out in case you have some sort of power problems.
I would try the neg terminal thing too. If that doesn't work i wonder if your head unit has some sort of security feature that requires a code to unlock?
01 SR5 SPORT
Build Thread
01-19-2011, 08:50 PM
Real Name: Sean
Real Name: Sean
Yeah the only thing i'm worried about with the battery terminal reset is that it might reset the car alarm and I'm not sure if it will go off or have to get reset somehow? Because I just took it into the shop and they replaced the battery and a few other things and the alarm started going off and I had to bring them the clicker to turn the alarm off . But now that I think about it, there was a sticker on the side of the window that said the radio will not work if it is removed. Haha wow guess I shoulda brought that up. But I didn't really think it would have any affect on the radio if I put it back in the same vehicle it was made for? I thought it just wouldn't work with any other cars. Have you guys ever heard of anything like that as a security feature on the headunits?
01-19-2011, 11:50 PM
There is no security feature on those head units. If there was, mine would have locked up when it sat in storage for months. It has to be something else. The 97-98 head units are the same, I think.
Here's a write-up if you want to check your work: 4Runners.org - Installing a Clarion DXZ545MP Head Unit
Edit: UNLESS the 97 Limiteds had a different headunit than my 98 SR5 had?
01-20-2011, 01:01 AM
yeah mine didn't have a security lock either i dont think... I sold it a while ago and the guy never called me to complain... so im assuming its all good.
So if you said you saw a sticker that said that then it should be an easy fix. you just gotta call dealership and give them the serial number of the head unit and they can get the code. The only thing with that is IF it is the security mode thing then I would think it would display code or something in the LCD??
as for the alarm, is it an aftermarket alarm? if so then i know there is a fuse you can pull that will just reset the computer correct me if im wrong guys but i think its the ECU fuse under the hood?
01 SR5 SPORT
Build Thread
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
