Old 08-24-2022, 08:51 PM #1
NoVA_T4R NoVA_T4R is offline
NoVA_T4R is on a distinguished road
Front upper control arm bushings - determination they are worn
I see nothing in the FSM and none of the posts describe how to check on whether or not the UCA bushings are worn out.
Or if there is some road test to determine worn UCA bushings.
Would appreciate any input on something that hasn't been touched on in previous posts.
NoVA_T4R is offline   Reply With QuoteReply With Quote
Old 08-24-2022, 09:22 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
How to check any suspension bushing:
1) Visually check bushing condition for cracks, chunks missing, crumbling, and generally not looking good.
2) Take pry bar and manipulate said bushings in any direction you can and see if it’s easier to move than other comparable bushings or you can see damage while moving the bushings.
3) Perform sudden stops while having someone watch from behind and from the side to see if any suspension geometry changes.
Bonus round: replace your bushings if they are old enough to legally drink in the USA or your 4Runner could have driven to the moon (238,855 miles) and you suspect you might have bad bushings.
Old 08-24-2022, 09:47 PM #3
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you figure out they are worn, this video will help you swap them out.
t
Old 08-25-2022, 12:22 AM #4
Storm01's Avatar
Storm01 Storm01 is offline
Storm01 is on a distinguished road
Storm01's Avatar
I was able to grab my 12-6 o'clock position on my wheel and check the bushings in my UCA; they had a good amount of play in them. However, best tried and true way would be with a pry bar and visual test like others said.
Storm01 is offline   Reply With QuoteReply With Quote
Old 08-25-2022, 01:10 PM #5
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
This is a great example of "When in doubt, swap it out".
I took a pry bar to my UCA before I swapped it out and was stunned at how much movement there was.
Poly, OEM rubber, Replacement UCA - whatever is your preference, will be a huge improvement in steering, tracking, etc.
Study Tim's awesome video for all the details. May be worth tackling the UBJ at the same time.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 08-25-2022, 06:00 PM #6
Tim,
Watching your video was what motivated me to consider doing this job. I was wondering if the owner of the vehicle that you did the UCA bushing replacement reported any noticeable improvement in handling or vibration minimization after the replacement.
Finally, I'm not a suspension expert, so I'm asking this for my education and perhaps those of the other forum members:
What impact would replacing the upper ball joint but not the UCA bushings have on handling or vibration?
Conversely, what impact would replacing the UCA bushings but not the upper ball joint have on handling or vibration?
Thanks in advance.
Old 08-26-2022, 02:11 AM #7
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Tim,
Thanks in advance.
My friend Jordan, If I'm remembering correctly wasn't experiencing any vibrations. He just wanted to replace the bushings as preventative maintenance. You can check the balljoints for joint play by using a prybar to detect any joint play. If there's no play, the joint is good. There can be minute play and the joint is still considered good. So, I would only replace the UBJs if they have gross play.
If you're getting vibrations, I would suspect worn control arm bushings but have you ruled other things out like wheel balancing. 9 times out of 10, it's a wheel balancing problem.
Old 08-26-2022, 11:12 AM #8
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
Tim,
replace them all and fix that problem :-)
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
bushings , posts , test , uca , worn
FS: New 3rd Gen T4R OEM Upper Control Arm Bushings - AL, $100 Unner For Sale: T4R Items 4 02-19-2018 08:11 PM
Upper Control Arm bushings joshua.adams.63 3rd gen T4Rs 4 04-29-2016 06:24 AM
What's the long term consensus on poly front upper/lower control arm bushings? goodgnus 3rd gen T4Rs 6 01-02-2016 02:25 PM
95 4x4 upper & lower control arm bushings replacement HELP!!! and rear bushings??? mark808 Classic T4Rs 18 07-08-2013 01:11 AM
Upper control arm bushings (do poly bushings exist?) jamess 3rd gen T4Rs 20 02-21-2011 04:07 PM
