incase someone told you the dash needs to come out to do this job, You absolutely do not need to remove the dashboard to remove the easily accessible evaporator and Switching valve, you only need to remove the glovebox, its a pretty easy job, of course you'll need a new dryer receiver aswell as a vacuum pump and recharge kit.
