Old 09-16-2022, 03:20 PM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by GunslingerT4R View Post
I’ll be installing mini cats most likely.
What are you going to do about the upstream oxygen sensor since it will no longer be reading both exhaust banks?
Old 09-16-2022, 06:26 PM #17
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
This is the part I’m interested in, I’d imagine you would need some sort of X pipe to put the sensor in since I don’t think you could make two sensors work
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 09-16-2022, 09:00 PM #18
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
as far as I know, he will be ok by reading only 1 bank of the two no problem. You read 3 cylinders and assume the other 3 are at the same ratio. Some people have been running like this forever.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 09-17-2022, 09:12 AM #19
GunslingerT4R's Avatar
GunslingerT4R GunslingerT4R is offline
GunslingerT4R is on a distinguished road
I’m going to do an H pipe to allow for more even flow of exhaust. Oh and btw they fit like a glove. Haven’t bolted them in yet, just mocked them up.
GunslingerT4R is offline   Reply With QuoteReply With Quote
Old 09-17-2022, 04:42 PM #20
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Cool they fit! Have you test-fitted the included Y-pipe?
I wonder if using an equal-length Y would give it a nice, smoother tone like the newer Tacos with an equal-length Y.
Old 09-18-2022, 10:32 AM #21
No I’m not using the Y pipe. Going to cut the ends of the headers and weld V bands on and connect them with a fabricated H pipe and run true dual exhaust. Installing an o2 sensor on the h pipe and a mini cat on one of the exhausts
Old 09-18-2022, 10:27 PM #22
Real Name: Patrick
Real Name: Patrick
You’ll need the first oxygen sensor to be upstream of the catalytic converter
Old 09-19-2022, 06:49 PM #23
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
BTW did you rebuild the engine or just "refresh" the heads?
Old 09-25-2022, 09:43 AM #24
Yep. It will be. Waiting on a side job to get the rest of the parts. Got the header flanges cut off and the first V bands welded on. Stainless steel exhaust pipe is kinda pricey lol
Old 09-25-2022, 09:44 AM #25
I had a head gasket failure, so I hade the heads resurfaced and checked the block for cracks and clearances.
Old 10-01-2022, 05:31 PM #26
3.4l 5vz-fe headers-img_0829-jpg
3.4l 5vz-fe headers-img_0828-jpg
Got them installed the other day. Just waiting for some more funds to become available to buy the rest. Does anyone know about valve clearances? I thought you always checked with the lobes facing up but what I’m seeing on videos is different.
Old 10-01-2022, 09:30 PM #27
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Correct, up or sideways, as long as the lobe isn't touching the shim. The book has you do it in 2 (if I recall) passes, rather than moving many times to get every lobe straight up, but you can do it either way
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 10-02-2022, 10:52 AM #28
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Attachment 400139
Attachment 400140
What I wouldn't give for a lift and tube bender in my shop, or else I'd be right behind you
Old 10-02-2022, 10:54 AM #29
There is a tool set to remove the shims. It takes practice using it…..
Old 10-02-2022, 07:57 PM #30
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I see some daylight between the pipe and the steering shaft! I think you got it.
Yes lobe pointing up or at least higher than the 9 o'clock or 3 o'clock positions. If it's facing any lower than that the cam lobe starts to taper and you'll get a bad measurement.
326WHP 347TQ
crossover , essentially , exhaust , headers , pipe
WTB 3.0 V6 headers Pab's For Sale: T4R Items 5 04-02-2015 05:24 PM
3rd gen Headers 4RUN0326 Want to Buy/Trade 0 12-16-2012 04:57 PM
headers 410toy 3rd gen T4Rs 2 04-30-2009 08:01 AM
Anyone using OBX Headers? LINY4Runner 3rd gen T4Rs 2 02-26-2009 06:55 PM
