Old 08-28-2022, 04:36 PM #1
GunslingerT4R's Avatar
GunslingerT4R GunslingerT4R is offline
GunslingerT4R is on a distinguished road
3.4l 5vz-fe headers
Does anyone know if the red back headers that are for the Toyota hilux fits the same engine on a 3rd gen 4runner? I ended up cutting my exhaust out while taking my heads out to redo the head gasket. Would rather straight pipe it out vs using the crossover pipe. So headers and dual exhaust is essentially what I am doing. Not for more horsepower just for ease at this point. Here is the link I was looking at.
Redback Headers Fits Toyota Hilux VZN167-172 5VZ-FE 3.4L Auto RBH276A | Sparesbox
GunslingerT4R is offline   Reply With QuoteReply With Quote
Old 08-28-2022, 05:29 PM #2
Makitso Makitso is offline
Makitso is on a distinguished road
That product is made for the Australian market with right-hand drive vehicles. Just looking at it, I don't think it will fit a 4x4 4Runner due to interference with the front drive shaft and transfer case. That is why the exhaust cross-over is behind the engine and the exhaust runs down the right side.
2000 4Runner Limited w/TRD Supercharger
And E-Locker
Makitso is offline   Reply With QuoteReply With Quote
Old 08-28-2022, 05:39 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold
Devbot's Avatar
Real Name: Devan
FWIW I've read headers require you to relocate TONS of stuff in the engine bay, so it might not be as easy as you assume it to be
Y2K Highlander Millennium Silver 3.4L auto @ 317k and climbing
Old 08-28-2022, 09:03 PM #4
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
Hilux may have a 5VZ-FE, but think of it as only the long block. The exhaust, intake, accessories and everything else is different. Toyota even changed the exhaust manifolds for the 4Runners from 96-00 and 01-02 that are NOT interchangeable.
Back to the question, no they will not fit. You'd have to use just the headers and fabricate your own downpipe and X or Y pipe as it'll hit the transmission and/or transfer case. You'll also lose ground clearance with custom piping unless you have an exhaust shop do it for you.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 240K miles.
326WHP 347TQ
Old 08-29-2022, 04:16 AM #5
I did two head gaskets by removing the exhaust studs from the heads.
Most of the studs came out just trying to remove the nuts.
Old 08-29-2022, 06:17 AM #6
That’s what I wanted to do. As I said I would run dual exhaust as long as the headers fit on the heads.
Old 08-29-2022, 08:30 AM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all
rdruss's Avatar
Real Name: Ron
I would email Redback and get their input.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 08-30-2022, 12:27 PM #8
Real Name: Jerod
Real Name: Jerod
They will fit the heads. What is unknown is how many other parts you'll have to relocate in order to get them to work. My engine is in a 98 4Runner and a significant amount of parts had to be moved and modified for my headers to fit, and those were made for my engine.
326WHP 347TQ
Old 09-11-2022, 04:36 PM #9
Well I ordered them any way. I can weld and modify them as needed. I will keep y’all posted with pics. Delivery date is Oct 4. Just got my heads resurfaced and going to start putting her back together.
Old 09-11-2022, 10:16 PM #10
Real Name: Jerod
Real Name: Jerod
If it's not too much trouble, I'd love to see a few photos of how the dual exhaust works out. What's your plan for the exhaust? Going to do an X pipe or a Y pipe? Or it is a true dual exhaust? I don't know your smoggy rules so not sure if that's an option.
326WHP 347TQ
Old 09-12-2022, 07:45 AM #11
I plan on doing true dual exhaust. That y or x pipe on the stock exhaust was a pain to remove. I ended up using a sawzall to cut it out lol. I’m in Maryland and plan on keeping the historic tags on it. Right now waiting on the headers to come in. Going to start cleaning the block and putting heads back in this week.
Old 09-12-2022, 06:21 PM #12
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Please keep us updated I’m very interested to see how these fit, what’s your plan for the o2 sensor when running a true dual?
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 09-16-2022, 01:18 PM #13
I’ll be installing mini cats most likely.
Old 09-16-2022, 02:19 PM #14
Got the headers today. They look like they will fit no problem. Exhaust studs line up perfectly3.4l 5vz-fe headers-68504522845__0a681038-98c8-41b9-b9cc-61d7190bc6f3-jpg
Old 09-16-2022, 02:46 PM #15
Real Name: Jerod
Real Name: Jerod
Got the headers today. They look like they will fit no problem. Exhaust studs line up perfectlyAttachment 399802
They look nice, I like the black.
The exhaust studs will be the least of your worries. My main concern will the the steering column and transmission.
326WHP 347TQ
crossover , essentially , exhaust , headers , pipe
WTB 3.0 V6 headers Pab's For Sale: T4R Items 5 04-02-2015 05:24 PM
3rd gen Headers 4RUN0326 Want to Buy/Trade 0 12-16-2012 04:57 PM
headers 410toy 3rd gen T4Rs 2 04-30-2009 08:01 AM
Anyone using OBX Headers? LINY4Runner 3rd gen T4Rs 2 02-26-2009 06:55 PM
