08-28-2022, 09:27 PM
Crank no start no check engine light no tach bounce on crank
Suggestions Anyone? '02 4runner, 6 cylinder. Owner replaced timing belt/water pump kit. He's not a mechanic but says he followed every step and took his time. He's a smart guy, a chemist.
He was in no hurry and the car was down for some time.
Afterwards car would crank but not start. He grew disillusioned, it sat for a couple of years. He bought a new 4 runner and gave the '02 to me for free. I had it towed to my house, yesterday.
Things I suspect might mean something about what's wrong: No check engine light symbol shows up with key on. No tach movement when cranking. I haven't checked spark as I believe there will be no spark if the computer doesn't detect crank rotation (?)
Any suggestions on where to start? I have an '03 but have never had engine problems. All my experience has been on vintage muscle cars.
Any suggestions appreciated.
Bill in Oregon
08-28-2022, 10:30 PM
Real Name: Patrick
Real Name: Patrick
Bill in Oregon
If the rpm gauge isn’t moving while cranking then there is a problem with the crankshaft position sensor. Most likely the sensor is unplugged or the connector isn’t fully seated.
08-28-2022, 10:40 PM
Engine ran > work was done > engine doesn’t run.
Seems pretty likely something wasn’t done right. A tooth could have gotten broken off the crank sprocket, or the cam sensor could be unplugged, or the timing was never set up right, or he also did valve covers and didnt reattach the plenum ground, just to name a couple easy options.
I also want to appreciate the irony: he’s a chemist, a smart guy. But he let’s a $10,000 vehicle sit for 2 years and gives it away. Hmmm….
I would figure this the hell out if I were you. That’s a gold mine.
08-29-2022, 08:25 AM
+1 with the crank tooth sprocket. Your biggest PITA will be getting three crank bolt loose.
I once witnessed a guy at a convenient store off I95 pouring antifreeze on his BMW engine. I told him that wasn’t where it was supposed to go. He told me “Don’t worry I am an engineer”. Well of course he was so I walked away in amazement.
08-29-2022, 11:23 AM
Real Name: Jon
Real Name: Jon
Some folks can be extremely book smart and at the same time absolutely no common sense. He is a non mechanical engineer. That's for sure
08-29-2022, 11:52 AM
Very much interested in how this turns out. I know that lack of tach bounce is a classic indicator of crankshaft position sensor inop - but not on all vehicles. Somewhere in the back of my head I think this was not the case on the 3.4L V6 in my 3rd gen. Have moved on to a 4th gen so can't confirm it....those of you saying it's the case, have you tested it?
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
08-29-2022, 01:49 PM
He also mentioned no check engine light………….
Do you have a scanner? Preferably one that can read live data…..
08-29-2022, 02:15 PM
Real Name: John
Real Name: John
Don't worry I am an engineer!
HAHAHAHA!
John
2002 TCM Grey Sport Edition
08-29-2022, 03:37 PM
Originally Posted by brillo_76
If the Crank position sensor not working it will not throw the fuel pump relay on. No rpm. Dead engine on a 3rd gen v6 .
OK...but do you normally get a tach bounce when starting? That is my question (and a line of inquiry for the OP). Is the absence of a tach bounce on the 3rd gen an indication that there is a problem with the crank position sensor (or wiring/associated gizmos)? Somebody try this and confirm it.
2004 Honda Accord
08-29-2022, 04:36 PM
Real Name: Patrick
Real Name: Patrick
Yes. RPM gauge will show rpm's while cranking. OP stated that the rpm gauge doesn't move when starting/cranking.
