11-02-2016, 01:56 AM
Sunroof Leak.. My Turn...
Hey all,
I knew that was gonna happen to me eventually.... Anyone else deal with this?
Is it as simple as ordering a new gasket and fitting it? or is this a dealership thing? Looks like a nice crack dry rot ..
Thanks.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
11-02-2016, 07:08 AM
I would check the front and rear drain tubes first and make sure the water is draining out of the channel.
11-02-2016, 07:29 AM
Real Name: Dave
Real Name: Dave
Are there rear drain holes? My 97 was leaking recently and I unclogged one of the fronts, but I didn't see any rear drains
97 4runner SR5 3.4 manual
Tundra/LC Lift with Bilstein 5100's on 285/70/17 BFG KO2
2" "Fat Pats" body lift; 1.25" All Pro wheel spacers
Turbo Build; Rear Bumper Build; Front Bumper Build
11-02-2016, 08:54 AM
Hey Guys,
I'll have a look around for drain channels... and the tubes while i'm at it... I'll report back when i find something.
Thanks.
Currently 194K
Cheers
11-02-2016, 08:58 AM
Real Name: Daniel
Real Name: Daniel
If there's an obvious crack, I doubt even a properly working drain would help that much. The drain simply keeps the water that gets through the gasket from getting to the headliner.
Because the gasket is not watertight for some genius reason.
There is a rear drain on my 99. I'd assume there would be one on a 97, but i don't know for sure.
My sunroof was leaking when I bought it, and after a bunch of research (though I did not confirm in person) it sounds like the sunroof/gasket are all one assembly that has to be replaced at the same time. I just RTVd my sunroof shut to deal with it later.
11-02-2016, 10:24 AM
This is true. You must purchase the entire glass/gasket as one piece. They aren't sold separately, at least not from Toyota. I don't know of any aftermarket options.
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
11-02-2016, 10:42 AM
There are rear drains, I think they empty out near the rear quarter panels. Water SHOULD fall into the sunroof assembly channeling and out the drains. But the top side trim / seal has a small gap towards the hood, I'd try sealing that. You can pour water in the sunroof channel, will be evident if the drains aren't working.
-2005 4Runner Limited V8 AWD - Toytec Boss Suspension, SPC UCAs, 285/70/17 Level 8 MK Wheels (17x8, -10), Tandem Rock Sliders
-1998 LX470 (Stock)
www.KeenanOffroadFab.com
11-11-2016, 08:45 PM
I stopped at the dealership today they told me the same thing... one entire piece glass/gasket... thing is they didnt have a price for me... i have to come back for that...
Anybody have an idea about what i'm gonna spend? $500?
Thanks
Currently 194K
Cheers
11-12-2016, 01:11 AM
Been dealing with the same thing on mine for months now. It gets a little annoying when every time you turn right water droplets sprinkle on your forehead.
I haven't found time to mess with it yet, but I'm just going to smudge a little black rtv silicone in there on top and bottom of the crack. I'd imagine that would stop the leak just fine and you'll probably never notice it's there.
11-14-2016, 12:28 AM
I Know what you mean.... I assume that crack thats there isn't supposed to be there and so there for we get leak... tomorrow i'll go back to the dealer and see what a new assemble will cost me.. I'm guessing that if i seal up that crack the water will just find another path.. Like those drains that everyone is talking about.
I'll keep everyone informed.
Currently 194K
Cheers
11-14-2016, 12:44 AM
Originally Posted by giguchan
I Know what you mean.... I assume that crack thats there isn't supposed to be there and so there for we get leak... tomorrow i'll go back tot he dealer and see what a new assemble will cost me.. I'm guessing that if i seal up that crack the water will just find another path.. Like those drains that everyone is talking about.
It's supposed to leak into the channels then drain. That looks like a crack in the window housing, not the drains. Look for a crack in the window housing and plaster it with rtv. My drains plugged and my window hadn't worked since I bought the truck so I rtv'd the crack between the window and the roof.
'96 4runner Limited - Automatic 4wd with factory E-locker - LT265/75r16 BF Goodrich KO2's - Toytech/Eibach front coils and LC 8 wraps with Bilstein 5100s all around - SPC UCAs - AOR Plate Front Bumper - 4xinnovations Rear Swingout Bumper - HD-SKO Sliders
11-15-2016, 09:15 AM
Currently $601.61 from Camelback.
P/N 63201-35040
11-15-2016, 10:32 AM
Real Name: Juan
Real Name: Juan
I just bought a whole sunroof assembly from my yard for 50.00 from a 98 to go into a 02. It's easy as heck to change out. Involves about 2 hours. Philips and a 10mm, pliers I forgot. You may get one at your local yard for a little more. Definitely not 500.00
While you're there clean out front and rear drain line with soap and water and blow air thru them. Make sure you clean the drain rail before you connect drain line.
11-15-2016, 10:41 AM
Real Name: Dave
Real Name: Dave
I've always been told NOT to blow air through the drain lines. You risk blowing the rubber drain line portion from the fitting, then you'd be asking for a lot of extra effort to fix it.
11-15-2016, 10:43 AM
Real Name: Juan
Real Name: Juan
Sir I mean when if you replace the sunroof. Yours is shot, there's a crack that's not worth fixing.
