Old 09-05-2022, 04:51 PM #1
ChromeT4R ChromeT4R is offline
ChromeT4R is on a distinguished road
Hose Throttle Body to Charcoal Canister
Need help finding OEM part number for a hose that connects from the throttle body to the charcoal canister. I don't know the name of the hose which is making it difficult to find the part. I know some of the parts are being discontinued. If this one is, what hose can I use as a replacement for OEM. I included some pics. I have a 2000 2.7L automatic 4runner. Thank you.
Hose Throttle Body to Charcoal Canister-throttle-body-hose-2-jpg  Hose Throttle Body to Charcoal Canister-charcoal-cansister-2-jpg
ChromeT4R is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 05:35 PM #2
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering is a name known to all Spiker Engineering is a name known to all Spiker Engineering is a name known to all Spiker Engineering is a name known to all Spiker Engineering is a name known to all Spiker Engineering is a name known to all
official vendor
I believe it's 23827-75080.
You are right, more and more of these hoses are becoming discontinued, I'm scrambling to collect the full set for my '97.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 10:15 PM #3
Great thank you! The part number sent me to a nice diagram with all the hoses with their part numbers. Next question, since I'm already tinkering with the charcoal canister and being that the plastic canister is getting old and brittle after 22 years, should I just go ahead and replace it? I plan on keeping this 4runner for at least another 20 years if I can keep it running. It has 215,000 miles. Like mentioned earlier, the parts for our 3rd gens are starting to get discontinued and since I'm in the process of restoring old cracked or brittle hoses I thought I should just replace the canister while the part is still available.
Old 09-06-2022, 09:45 PM #4
chapolito's Avatar
chapolito chapolito is offline
chapolito will become famous soon enough
chapolito's Avatar
I replaced that hose recently...just used some straight length from napa, a lot cheaper than a $40 formed hose. No issue getting it to snake the same path to TB.
chapolito is offline   Reply With QuoteReply With Quote
Old 09-06-2022, 10:30 PM #5
I'm assuming I just ask for PCV hose? If so are all the hoses attached to the charcoal canister PCV hoses as well? Most are as hard as a rock.
Old 09-07-2022, 02:23 AM #6
chapolito's Avatar
chapolito's Avatar
I asked for vacuum hose...I thought because it was in the vacuum diagram under the hood it would just be vacuum hose, but I realized after the last two hours reading about different hoses and I need to go change out that vacuum hose for fuel hose so the fuel doesn't breakdown the hose. From what I've read, most fuel hose (SAE J30R7) are rated for PCV & EEC, some even have that printed on them, or they may say fuel/emissions This video was helpful in explaining the different standards of fuel hose.
Thanks for asking the question so I could learn and fix my own mistakes!
Old 09-07-2022, 07:25 AM #7
Wow! Thank you for info. Sure it's easier to just go to the dealer and get the hose and not worry about making a mistake. But getting them at an auto part store does force one to learn what each hose does exactly and how all the parts of the engine work together.
Old 09-08-2022, 11:08 PM #8
chapolito's Avatar
chapolito's Avatar
I swapped mine this evening. It is a 5/16" hose and I needed 2 1/2 feet. Cost $6 from autozone.
Here is a photo of how it routes pretty cleanly from the charcoal canister to the TB despite not being molded:
Also, for future reference, here are some of the markings on two different fuel lines. They are both SAE 30R7 (or J30R7, same thing), but one mentions PCV/EEC while the other just says fuel line:
And finally, I cut open the vacuum hose I was using to see if there was deterioration...looked pretty clean.
Was I ok to keep using? probably. Will I worry less knowing it is the right hose? absolutely.
canister , hose , oem , part , throttle
WTB3rd Gen 1999 air hose (connects to throttle body) Lunarphase 3rd gen T4Rs 2 10-05-2015 09:25 AM
WTB 3rd Gen 1999 air hose (connects to throttle body) Lunarphase Want to Buy/Trade 0 10-04-2015 08:25 PM
need part # for hose goes on Throttle body Tucson Mike 3rd gen T4Rs 1 02-02-2013 10:13 PM
Sea Foam again...PCV hose or Throttle Body? swampy_swimmer 3rd gen T4Rs 3 07-06-2012 01:08 PM
Hose from charcoal canister Spencer 3rd gen T4Rs 3 04-11-2010 09:12 PM
