Old 09-07-2022, 02:56 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
You can also run the higher amp alts in the older rigs if you want. Just make sure you keep track of it. Probably be best to swap out the fuse and charging wire. Granted its 10 amps more and both the higher and lower modules don't exceed the 90 amp fuse in the older 3rd gens. ( 70 and 80amp)
Just don't make the mistake of putting the lower amperage one in the late modules.
The alt fuses are 1996-1998 [100 amp] 1999-2002 [120amp]
Rule of thumb is stick what matches the rigs. :-)
Old 09-07-2022, 03:20 PM #17
307Vintage 307Vintage is offline
Real Name: Clint
307Vintage is on a distinguished road
Real Name: Clint
The Denso from Rock Auto is a 70 Amp.
307Vintage is offline   Reply With QuoteReply With Quote
Old 09-07-2022, 03:26 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
1996-1998 are the 70amp ones
1999-2002 are the 80 amp ones
Your good.. :-)
Old 09-07-2022, 03:38 PM #19
Real Name: Clint
Real Name: Clint
Is the ground that goes from the firewall, by the heater valve, to the back of the passenger side head the only motor to chassis ground? I checked continuity on both that one and the battery to chassis and they were both good. But I am going to pull the motor to chassis and make sure it is clean.
Old 09-07-2022, 03:52 PM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
No that's the ground for the head.
Your negative terminal starter ground goes down the the block next to the oil filter. :-)
Old 09-08-2022, 07:12 AM #21
jross20's Avatar
jross20 jross20 is online now
jross20 has a spectacular aura about jross20 has a spectacular aura about jross20 has a spectacular aura about
jross20's Avatar
Originally Posted by 19963.4lsr5 View Post
You can also order a brush set from Toyota for around 25 dollars and instal them yourself. And save some money.
As long as you have a Japan spec Phillips screwdriver it’s easy.
Is there a part number for that set?
jross20 is online now   Reply With QuoteReply With Quote
Old 09-08-2022, 09:06 AM #22
19963.4lsr5 19963.4lsr5 is online now
Blowing Alternators
Do you know which Alt you have?
I think the 27370 number is a fully loaded 70a.
Edit: the two part numbers before the last number are the OEM and Denso part numbers for the Alternator. I’m pretty sure it’s for the 70a Alt. The 80a Alt is totally different.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 09-13-2022, 04:44 PM #23
Supergleep Supergleep is offline
Supergleep is on a distinguished road
I bought this a few years back to have a JIS screwdriver in the toolbox. It really does work better on any Japanese screws you have to deal with. Highly recommended
Vessel Megadora 980 Impacta P2x100 #2 Cross Point Impact Screwdriver - Phillips Head Screwdrivers - Amazon.com
Supergleep is offline   Reply With QuoteReply With Quote
Old 09-13-2022, 07:46 PM #24
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Good info. Are the bearings that come with the Maniac kits made in China? Guessing that's why you have the other part numbers listed. I always assumed they were and just bought rebuilt Denso alternators
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 09-14-2022, 12:25 AM #25
CougarHound's Avatar
CougarHound CougarHound is offline
CougarHound is on a distinguished road
I'm still amazed that my original one still works....It might help to take apart the broken one and figure out why it is failing. I think there is a diode in there that you can check with a multimeter.
Electrical problems are not fun. What happened to the other car?
CougarHound is offline   Reply With QuoteReply With Quote
Old 09-14-2022, 07:45 AM #26
The Manaic kit I used just for the VR. It was made in China. Didn’t feel like spending over 100 dollars for an OEM or napa voltage regulator for the sake of troubleshooting. The VR is still going strong. The problem ended up being a bad diode in the bridge…..
ago , alternators , replaced , stopped , working
DC Power Alternators the_josh 4th Gen T4Rs 1 10-11-2020 06:38 PM
A/C Starts Blowing when in Defrost(windshield blowing) setting Frank12 3rd gen T4Rs 9 10-21-2017 07:23 PM
alternators 3bears 3rd gen T4Rs 15 03-07-2016 01:40 PM
Interchangeable alternators. BigRyan1986 Classic T4Rs 24 04-25-2015 12:29 PM
***** ass alternators? clys 3rd gen T4Rs 1 06-14-2012 08:23 PM
