Old 09-12-2022, 04:08 PM #16
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Originally Posted by brillo_76 View Post
Valid point.. However, I don't torque spark plugs. I snug them until they crush the crush washer and use a small handled ratchet to tighten then up. you have to drop the torque spec 25% if using anti seize.. If you don't your will over torque things..
The Denso plugs I used didn't even have a torque spec. Instructions said turn 1/4-1/2 turn past initial contact.
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 05:13 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Originally Posted by texadelphia View Post
I've never felt comfortable with anti-seize when the plug manufacturers don't recommend using it and lubricated threads and dry threads have different torque specs.
I been anti seizing them for years.. I just tighten them down and that is it..:-)
No torquing required at all. Maybe the anti seize keeps my threads clean..
This is just how I been doing it for the last 33 years. You can do it however you see it fit for you. No problemo :-)
Old 09-12-2022, 05:14 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
1/2 turn past initial contact would crash the crush washer to seal it well..
Old 09-13-2022, 08:05 AM #19
JoeT4R's Avatar
JoeT4R JoeT4R is online now
JoeT4R is a jewel in the rough JoeT4R is a jewel in the rough JoeT4R is a jewel in the rough JoeT4R is a jewel in the rough
JoeT4R's Avatar
I believe the torque spec is either 13 or 14 foot pounds, though I would do some research first. I think I saw that in the FSM.
Sent from my SM-S908U using Tapatalk
2001 SR5 4WD | 320K+ | Sonoran Steel 1.2 | Build Thread
JoeT4R is online now   Reply With QuoteReply With Quote
Old 09-13-2022, 10:26 AM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Steel threads into aluminum mostly are always less the 15ft pounds. Just like the valve pan gasket torquing.
Old 09-13-2022, 11:09 AM #21
96RedRunner is just really nice 96RedRunner is just really nice 96RedRunner is just really nice 96RedRunner is just really nice 96RedRunner is just really nice
Me and @brillo_76 been doing plugs the same for a combined 70 yrs same out come
Old 09-13-2022, 12:06 PM #22
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup. I have good success with the anti seize.. Folks can do as they wish.
Old 09-13-2022, 12:50 PM #23
So what I'm hearing is take out all the plugs I just installed, put a dab of anti-seize on them, and torque them to 11 ft-lbs.
Old 09-13-2022, 01:08 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nope. You do as your want. We just say what you we did. I would do as you wish..If they are in and snug your good.
Old 09-13-2022, 01:09 PM #25
JoeT4R's Avatar
JoeT4R's Avatar
You certainly can, although I don't believe it to be absolutely necessary. Nor have I ever applied anti seize to mine before. Just be careful when torquing the plugs and you should be just fine.
Old 09-13-2022, 01:19 PM #26
Always...
Old 09-13-2022, 01:59 PM #27
Philz Philz is offline
Philz is on a distinguished road
Originally Posted by alumarine View Post
I'd start with your plan to soak it in penetrating oil and then work it very slightly back and forth.
Spray, wait and repeat.
Just went through this on my town car. I did it with the motor cold.
It has aluminum heads.
☝️is proper way to remove In warm air temps.
Under 32 degree air temp warm vehicles for couple min , turn it off of course then follow above
96 4-Runner Limited
Philz is offline   Reply With QuoteReply With Quote
Old 09-13-2022, 02:13 PM #28
Well I ran an errand, got home, let it sit for an hour and tried to take it out. Still only turned 1-2 rotations and then froze up again. Going to get some liquid wrench on it tonight and let it sit overnight.
Old 09-13-2022, 02:27 PM #29
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Take it out while the engine is hot
Old 09-13-2022, 04:22 PM #30
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Especially if they are snug to begin with... :/
bind , oil , penetrating , planning , seized
transfer case fill plug is seized, should I use a cordless impact Pyral 3rd gen T4Rs 15 11-20-2021 12:58 PM
spark plug rounded, remove spark plug tubes? Danger Mouse 3rd gen T4Rs 0 05-02-2021 03:43 PM
Spark Plug cyl.3, this ok? UrbanRunnerNY 4th Gen T4Rs 8 06-08-2019 09:16 AM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Rockauto 0 01-12-2017 02:52 PM
The Best Spark Plug MaliciousClout 4th Gen T4Rs 68 12-30-2016 01:05 PM
