Old 09-13-2022, 05:23 PM #31
162435's Avatar
162435 162435 is offline
162435 will become famous soon enough
162435's Avatar
Originally Posted by brillo_76 View Post
I been anti seizing them for years.. I just tighten them down and that is it..:-)
No torquing required at all. Maybe the anti seize keeps my threads clean..
This is just how I been doing it for the last 33 years. You can do it however you see it fit for you. No problemo :-)
My method as well. I replace the plugs every 25,000 miles (NGK BKR5EKB-11). Anti-seize and hand tighten quite snuggly once I feel the crush washer make contact. No issue in 21+ years & 517,800 miles.
Andreas
2001 SR5 4Runner 4WD, Dorado Gold, 546,XXX 1-owner miles
2002 4Runner, Dorado Gold, 226,XXX miles
1998 4Runner, Oxidized, 265,000 miles
2014 Audi A4 quattro, Monsoon Gray
1995 Porsche 993, Polar Silver
162435 is offline   Reply With QuoteReply With Quote
Old 09-13-2022, 05:44 PM #32
texadelphia texadelphia is offline
texadelphia will become famous soon enough
I'll give it a shot when it's hot instead of warm and report back.
Sent from my moto g(7) power using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 09-13-2022, 06:20 PM #33
Did some more digging. Denso's website says torque spec is 15-22 ft-lb in an aluminum head or to do the 1/4-1/2 turn past contact if you don't have a torque wrench. FSM says 13 ft-lb. Denso also doesn't say to not use anti-seize like NGK. They just say to reduce torque spec by 30% if using anti-seize. So I think I might pull them all back out once I get this stuck one out, put a light coating of copper anti-seize on them, and reinstall to 9 ft-lb (109 in-lb). Wish I would have done all this digging before I installed them the first time and crushed all the washers but it probably doesn't matter that much.
Old 09-13-2022, 07:56 PM #34
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
This is all a part of the learning experience. And from this point forward you'll always know what to do and can even lend assistance to others doing it. All a part of the game!
Sent from my SM-S908U using Tapatalk
Old 09-13-2022, 07:57 PM #35
Got it out! Got back from a drive and gave it another shot. It didn't come out easily and I was holding my breath the while time but I just kept working it back and forth with quarter turns.
Hopefully about 45 minutes with the hood up is long enough for it to cool back down before I install the new one because I need to head back out in a bit.
Old 09-13-2022, 07:59 PM #36
Funny thing is I've been working on cars casually for like 25 years and just never ran into a stuck plug before.
Old 09-13-2022, 08:11 PM #37
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Just wait till you come across a cross threaded spark plug. Then you really have fun.
Is it only one spark plug that's snug or several of them?
Old 09-13-2022, 08:27 PM #38
It was the entire passenger bank. The driver side came out easily but interestingly enough, that side also looked like the valve cover gasket had been replaced while the passenger side looked original.
Old 09-13-2022, 09:44 PM #39
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Interesting. One entire head. Interim in deed.
Old 09-13-2022, 09:52 PM #40
The valve train on that side was also noticably more varnished.
Old 09-13-2022, 10:09 PM #41
162435's Avatar
162435's Avatar
I picked up a one-owner '02 for my daughter in June 2020 with 199,000 on the clock. Always dealer serviced.
When I test drove it, the truck could barely reach highway speeds and bucked at different throttle positions. The deal was way too good to pass up, so I took a chance that it was something easy and not the tranny.
This is what I found when I pulled the plugs:
I installed new NGK plugs and three new plug wires from Toyota. Ran perfect.....
Andreas
Old 09-13-2022, 10:12 PM #42
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Maybe someone changed a head in the past. Hard to say when thru are used.
Old 09-13-2022, 10:17 PM #43
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Andreas
That's nothing I had one that had original spark plugs in at 215k. The spark plug electrode broke off and is stuck In the piston surface. The engine would misfire as the ignition would cause the porclin to chatter as nothing was holding still anymore and half the center of the plug would move every fire on that cylinder.
Old 09-13-2022, 10:53 PM #44
Andreas
Mine looked marginally better than that and the dielectric grease on the electrodes had turned into the mosquito resin from Jurassic Park.
bind , oil , penetrating , planning , seized
transfer case fill plug is seized, should I use a cordless impact Pyral 3rd gen T4Rs 15 11-20-2021 12:58 PM
spark plug rounded, remove spark plug tubes? Danger Mouse 3rd gen T4Rs 0 05-02-2021 03:43 PM
Spark Plug cyl.3, this ok? UrbanRunnerNY 4th Gen T4Rs 8 06-08-2019 09:16 AM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Rockauto 0 01-12-2017 02:52 PM
The Best Spark Plug MaliciousClout 4th Gen T4Rs 68 12-30-2016 01:05 PM
