Old 09-11-2022, 11:18 PM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Seized Spark Plug
Changed my plugs today and the 3 on the passenger side were all really tight coming out. I couldn't get one to budge. It would turn a couple turns and then just bind up. I'm planning on hitting it with penetrating oil and kind of loosening and tightening it to work the penetrating oil in. Anyone have any other suggestions?
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 09-11-2022, 11:29 PM #2
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I'm not a plugologist or anything, but I change mine every 2 years. I'd first try the penetrating oil just as you are planning to do. Good luck.
pluton is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 12:02 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Thread it back in, install the other spark plugs, run the engine until it’s at operating temp then try to take the spark plug out.
Old 09-12-2022, 02:10 AM #4
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
When it turns, does it turn freely? Or is it gritty feeling? I'd soak it in PB blaster, but also trying to remove it after running the engine to operating temp sounds like a good idea too. Maybe some dingus installed that plug when the engine was hot.
Old 09-12-2022, 08:39 AM #5
It feels "squeaky" when I try to back it out like it's binding, no grittiness. All three on the passenger side felt that way but I was able to power out the front 2. At first I thought they were cross threaded but the new ones went in easy.
I'll try the operating temp thing and then hit it with penetrating oil if that doesn't do it. If I get it out should I let the engine cool back down before reinstalling?
Old 09-12-2022, 08:43 AM #6
alumarine alumarine is online now
alumarine will become famous soon enough alumarine will become famous soon enough
I'd start with your plan to soak it in penetrating oil and then work it very slightly back and forth.
Spray, wait and repeat.
Just went through this on my town car. I did it with the motor cold.
It has aluminum heads.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is online now   Reply With QuoteReply With Quote
Old 09-12-2022, 09:28 AM #7
JohnMc JohnMc is offline
JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light
At least it's moving. Squeaking is a good sign, boogered threads aren't likely to squeak.
JohnMc is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 09:29 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
I agree that moving is a good thing. You get it just work it slowly..
Old 09-12-2022, 09:59 AM #9
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Sounds like you are being careful which is good, not an area you want to have problems.
As spark plugs are cheap I change them out frequently to avoid any sticking issues.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 10:00 AM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I mostly just anti seize them and never have issues after that myself.
Old 09-12-2022, 10:07 AM #11
tacoma2002 tacoma2002 is offline
tacoma2002 is on a distinguished road
Agreed. Once its at OT spray some GOOD penetrating oil in around the plug. Kroil or PB Blaster works great.
tacoma2002 is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 12:22 PM #12
I've never felt comfortable with anti-seize when the plug manufacturers don't recommend using it and lubricated threads and dry threads have different torque specs.
Old 09-12-2022, 03:05 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Valid point.. However, I don't torque spark plugs. I snug them until they crush the crush washer and use a small handled ratchet to tighten then up. you have to drop the torque spec 25% if using anti seize.. If you don't your will over torque things..
Old 09-12-2022, 03:13 PM #14
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
With aluminum heads I use a 1/4 drive and an adaptor.
Sometimes if the spark plug wasn’t sealed in the head the gasses and carbon can creep up 3-5 threads and really make it a bugger to remove.
In order for penetrating oil to work the plug needs to be backed out a thread or so.
Old 09-12-2022, 03:28 PM #15
Cej255 Cej255 is offline
Cej255 is on a distinguished road
Always get the engine up to temp with aluminum heads.
Cej255 is offline   Reply With QuoteReply With Quote
bind , oil , penetrating , planning , seized
transfer case fill plug is seized, should I use a cordless impact Pyral 3rd gen T4Rs 15 11-20-2021 12:58 PM
spark plug rounded, remove spark plug tubes? Danger Mouse 3rd gen T4Rs 0 05-02-2021 03:43 PM
Spark Plug cyl.3, this ok? UrbanRunnerNY 4th Gen T4Rs 8 06-08-2019 09:16 AM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Rockauto 0 01-12-2017 02:52 PM
The Best Spark Plug MaliciousClout 4th Gen T4Rs 68 12-30-2016 01:05 PM
