Old 09-12-2022, 12:02 AM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Oil in plenum
Had my plenums off today to do the valve cover gaskets. First time I've had them off since I bought it. There was a layer of oil all over the inside of the upper and lower plenum and the intake manifold. I looked in the intake pipe and there was some at the very end where it attaches to the throttle bottle. Looked like maybe it was coming in from the vacuum line that attaches right there.
Any thoughts on what this could be or what things I should be looking at? I replaced the PCV valve today when I had the valve covers off but the old one didn't seem like it had failed.
Also, is there a product I can use to clean the the oil out of the intake without having to take it off the car?
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 08:45 AM #2
alumarine alumarine is online now
alumarine has a spectacular aura about alumarine has a spectacular aura about
Over time oil will settle in the bottom of the intake manifold depending on it's design.
It usually comes from the PCV. No cause for alarm.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is online now   Reply With QuoteReply With Quote
Old 09-12-2022, 09:40 AM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Some folks like to use catch cans, here's an example:
Amazon.com: EVIL ENERGY Baffled Oil Catch Can,Oil Separator Catch Can 300ml Universal Aluminum Black : Automotive
My experience with German autos is they come with one, they give it a fancier name, Oil/Air Separator. Some autos need them more than others, especially GDI engines of which ours are far from it, so as alumarine said, nbd, in these type engines.
Old 09-12-2022, 11:33 AM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yes, a catch can would be the way to keep your intake cleaner from oil blow-by. And, we have a video on how to install one.
t
Old 09-12-2022, 12:03 PM #5
I never considered a catch can on a non direct injection engine.
Old 09-12-2022, 01:21 PM #6
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
How many miles does it have? Over time, the rings wear, and more compression leaks into the crankcase and has to come out viat that PCV system. The higher the volume, the faster it moves, and the less effective the oil/air separators get, to the point where more oil gets into the intake.
It's not even particularly a huge problem then either, up until it gets so bad that it starts smoking out the tail pipe and clogging the cat. Or need a quart of oil added every 500 miles.
JohnMc is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 01:25 PM #7
I'm just over 260K on the odometer. The exhaust never smokes and it uses maybe a half quart every 5000 miles or so.
I was more concerned with potential carbon build up on the valves but I guess because this isn't a direct injection engine the fuel spray should be keeping the valves pretty clean.
Old 09-12-2022, 01:33 PM #8
Yeah, no worries. Check back in after another 260K miles, lol.
Old 09-12-2022, 02:03 PM #9
GM makes a foaming upper engine cleaner that I’ve used often decarboning my old 96 Saturn SL1. Sadly the can recommends spraying through the throttle body which won’t work with air not flowing through the MAF sensor. Or mine won’t run with the inlet tube removed.
It’s just the condensing oil vapor you see from the PCV system.
Old 09-12-2022, 03:03 PM #10
Well I picked up a can of Seafoam spray with the little hook that goes between the throttle body and intake hose. I figure it can't hurt.
Old 09-12-2022, 04:00 PM #11
jgue467's Avatar
jgue467's Avatar
Even older BMW, Porsche, Audi and MBs come with one from the factory standard, much larger than the example I posted, they're Serious about it for a reason.
Interestingly enough, Kia/Hyundai GDIs don't come with one and they suffer for it.
Old 09-12-2022, 04:37 PM #12
My 2008 A4 didn't have a catch can but had an "oil separator" system integrated into the valve cover. It didn't work worth a damn though. Part of my "regular maintenance" was taking the intercooler pipes off and dumping out about 4 oz of oil at every oil change. It didn't leak a drop onto the ground but it burned up a quart every 1200 miles. I suspect that car also had bad oil control rings which likely contributed to the problem.
Old 09-12-2022, 05:06 PM #13
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I also did a catch can back in 2020, can confirm it does catch stuff. each oil change about 2-3 ounces of black goo get cleaned out. Not a lot but stuff does get pushed out the PCV path.
https://www.toyota-4runner.org/3494875-post182.html
Old 09-12-2022, 05:33 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I was never really concerned about the PCV valve venting into the intake that will coat the plenums with oil.. The last valve pan cover gasket job i did. I just cleaned them out with brake cleaner.
If your going to clean in front of your intake throttle body, you really have to be careful not to jack up the IAC valve that controls your idle. Many years ago I thought I would just clean that off with brake cleaner while the engine was running ( well after a week, my idle was working properly again) So I do not recommend that as I was lucky i didn't have to rebuild and clean the IAC out. :-(
Old 09-12-2022, 07:02 PM #15
I didn't even think about that. Wouldn't it just clean out the IAC too though?
Sent from my moto g(7) power using Tapatalk
attaches , intake , looked , oil , valve
Intake Plenum on 5VZ-FE Mudflaps 3rd gen T4Rs 18 04-02-2021 03:36 PM
WTB: 3.4 Intake plenum set - KY Taylor20 Want to Buy/Trade 4 05-08-2018 04:30 PM
Fuel in plenum Daneums 3rd gen T4Rs 11 04-12-2018 06:48 PM
Plenum removal nicnmike Classic T4Rs 9 10-21-2015 02:10 PM
Oil on intake plenum? jreask 3rd gen T4Rs 11 05-16-2013 12:54 AM
