Old 09-15-2022, 07:24 PM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Seat belt fix or replace?
My driver side seat belt has started to fray a bit where the buckle rides most of the time. Is there a hack to fix it before it gets worse or is it just a matter of getting a new OEM one when it gets bad enough?
Sent from my SM-T380 using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 09-15-2022, 08:56 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can get an oem one. Or there is a company out there that rebuilds them with new springs etc
Like Seat Belt Repair Service & Airbag Module Reset - Safety Restore
I am sure there a several other companies out there. As if the passenger side has been discontinued it will not be long before the drivers side is too in the earlier years.. :-(
Old 09-15-2022, 08:59 PM #3
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
best to replace it, "fixing" a seatbelt can be extremely unsafe. If you want one on the cheap I'd check a pick n pull but if not i'd go with Jon's site if you want a brand new one.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 09-16-2022, 08:35 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes being they are safety devices it's better to replace. Besides I replaced my 2 fronts off my parts mobile and the springs didn't last a week. Don't waste your time with used..
Old 09-16-2022, 05:51 PM #5
lockedlex's Avatar
lockedlex lockedlex is offline
lockedlex will become famous soon enough
lockedlex's Avatar
Rules I live by:
1) If it can leave you stranded, get ORIGINAL TOYOTA Parts only (LBJ, Radiator, belts, hoses, gaskets, etc).
1b) If it can't, OEM/Aftermarket is fine (bushings, bulbs, shocks, etc).
2) If it involves safety, like belts, airbags, bolts, etc. Get new (or equiv.) and only original Toyota Parts. I assume Toyota still sells this new?
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
lockedlex is offline   Reply With QuoteReply With Quote
Old 09-16-2022, 09:03 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Depends example:
early years driver side only msrp $ 219.39
MSRP
2001 both fronts are availble MSRP $ 346.90
Old 09-16-2022, 09:30 PM #7
Camelback has the driver front for about $150 but says the "right" side is discontinued. Are they ambidextrous?
Mine is a '97.
Sent from my moto g(7) power using Tapatalk
Old 09-16-2022, 10:15 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Mine is a '97.
The passenger and drvers are mirrors of each other. They are not interchangeable. Hence why they are different part numbers.
Old 09-17-2022, 06:14 AM #9
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I had Safetyrestore.com rebuild my 2001 drivers belt in 2017 lil less than $100.
I would guess it cost more now.
Old 09-17-2022, 01:33 PM #10
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I have used safty restore now 4x times, it's just like new and they use OEM parts if anything needs to be replaced.
it has been my experience that it's just the webbing that needs to be replaced. I feel 100% safe with the repaired belts. they clean and service the winding part, they work just like new.
Old 09-18-2022, 12:23 AM #11
The problem with using Safetyrestore is I'd have to drive around without a seatbelt until they shipped them back.
Old 09-18-2022, 10:52 AM #12
Real Name: Mark
Real Name: Mark
Get one from junkyard send for rebuild.
Old 09-18-2022, 11:23 AM #13
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Just buy a new one. The parts are so intricate in the lock mechanism that it’s silly. Some models have the explosive squib in them.
There are places that rebuild the retractable and re use your webbing. Seat belt planet does new webbing, but doesn’t do retractables.
I’ve been replacing all of mine. The rears required reusing and washing the webbing since tan is discontinued. All I did was swap out the grey new for my reused tan ones.
The front I just went all new. Yeah it’s spendy. But it’s like 4-5 tanks of gas. I guess my thought is if the seat belts to expensive to fix maybe the car is too expensive to have?
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 09-18-2022, 11:40 AM #14
NegroTundra NegroTundra is offline
NegroTundra is on a distinguished road
SafetyRestore is great. Used them twice now for driver side belts on two different 3rd gens. Wouldn't hesitate to use again.
00 T4R 3.4L Sc'd Locked 4x4 (140k)
98 T4R 3.4L 5-Speed Locked 4x4 (280k)
16 Dodge Ram 2500 6.7L Cummins fully deleted
NegroTundra is offline   Reply With QuoteReply With Quote
Old 09-18-2022, 04:47 PM #15
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Curious and following.
Sent Safety Restore an email asking about rewinding/reclocking my tired 99 driver belt
Anyone have the oak PN handy?
I found 73220-35471-E0
Cost is only $169 from the dealer...
EDIT: F it, ordered a new one and will send mine out for repair when I swap em
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
belt , fix , matter , seat , started
Replace seat-belt webbing T.Q.. General Discussions 1 07-29-2020 07:37 PM
Replace Rear Seat Belt jvilone 5th gen T4Rs 3 01-28-2015 03:49 PM
Replace Seat Belt ? Que 3rd gen T4Rs 1 12-11-2014 07:36 PM
How to replace rear seat belt buckle? 034G 4th Gen T4Rs 2 04-06-2012 08:05 PM
How do I replace a seat belt? iontrap Problems & Warranty Issues 1 12-08-2007 01:05 AM
