Old 11-03-2022, 12:57 AM #16
ZSW99 ZSW99 is offline
ZSW99 is on a distinguished road
I had a similar stalling issue that I chased for a long time that ended up being o2 sensors. I never had any codes but it would idle low especially when hot outside and if it did die it would instantly be off instead of stumbling, dropping in rpm then dying.
I went through 6 months of changing stuff, every time it would be good for a few hundred miles then come back. I finally figured out that the o2 sensors were causing it to learn to run lean and disconnecting the battery was resetting the ecu which would make it run great until it learned to run lean again.
99 SR-5 Highlander Elocker, 1.5” body lift, Ironman FCP coilover, FJ cruiser bilstein lift coils and fj80 kyb rear shocks, JBA ucas, TC gussets, custom front & rear tube bumpers, poly bushings all around, 33/12.5/15 on steels. 396k
98 Base 4x4 3rz. 5100s and ome coils. TBU. 360k
96 Taco rcsb 4x4 3rz 320k
ZSW99 is offline   Reply With QuoteReply With Quote
accelerating , check , engine , light , stop
Dealer 'fixed' stripped thread but threads are in fact not fixed Toronto4runner2 Problems & Warranty Issues 2 08-06-2022 05:48 PM
Stalling on 4th Gen JP4RNR Problems & Warranty Issues 3 12-28-2012 01:20 AM
Stalling jroberts 3rd gen T4Rs 2 08-02-2012 01:16 AM
5th Gen ('12) Stalling Out? Infrared013 5th gen T4Rs 2 05-19-2012 06:43 PM
Stalling GreenRunner Problems & Warranty Issues 4 07-06-2007 07:46 PM
