Old 09-21-2022, 08:04 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nothing wrong with the Spill and fill method at all. I use the fluid bucket exchange method at 100K but that is me.. :-)
Old 09-22-2022, 12:50 PM #17
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
i use valvoline max life ......full synthetic
also run a magnafine in line filter
Old 09-22-2022, 04:09 PM #18
mikeferg's Avatar
mikeferg mikeferg is offline
mikeferg will become famous soon enough
mikeferg's Avatar
I do mine every other oil change 12k miles
mikeferg is offline   Reply With QuoteReply With Quote
Old 09-22-2022, 09:07 PM #19
I use the magnafine also and change it every other year.
Old 09-22-2022, 10:23 PM #20
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Same here. I made the switch a couple years ago to Maxlife. I replace the magnefine filter every other drain and refill. I do drain and refills every 10k so I replace them every 20k. The filters are rated for 30k miles though.
Old 09-23-2022, 07:41 AM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am just curious, how does the fluid look at 10k mile change intervals?
Old 09-23-2022, 08:08 AM #22
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I do annual drain and fills of my A340F and thr fluid remains the same color as it does pouring in. So far it has worked well for me.
I use either AMSOIL or Valvoline MaxLife ATF. I typically do it at the beginning of the year. I get out about 4.1 to 4.2 quarts.
Sent from my SM-S908U using Tapatalk
Old 09-23-2022, 03:48 PM #23
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Fluid looks darker than new but no where close to reddish brown. It's not pinkish red like new fluid but closer to a solid darker red color. My trans gets worked harder than some. In that 10k miles, It probably went through a few wheeling trips and other mountain driving.
Some might think 10k drain and refills are excessive but I don't think so. The old rule was doing a full exchange every 30k miles. When you do a drain and refill, you get out around 4-4.5 quarts which is around 1/3 of the 12 quart capacity. By doing 10k drain and refills, I've essentially exchanged out the system capacity over a 30k mile period. I know drain and refills are a dilution process and aren't a true exchange or flush, but it's very effective to keep the fluid in great shape.
Waiting 30k miles to do a drain and refill, in my opinion, is grossly insufficient to keep your fluid in good shape, especially if the person does any mountain driving or 4wheeling where higher trans temps are achieved. With 30k drain and refills, you're only exchanging out the system capacity every 90k miles.
Fluid is affordable and drain and refills are simple to perform. It might be excessive, but I want to give my transmissions the best chance at a long life.
Old 09-23-2022, 06:23 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nothing wrong with what you are doing.. :-) Thanks, I was just curious if it was starting to change already and the from your information that is a yes. :-)
Old 10-02-2022, 02:18 PM #25
RobS10's Avatar
RobS10 RobS10 is offline
RobS10 has a spectacular aura about RobS10 has a spectacular aura about
RobS10's Avatar
Two last questions...how many quarts does it take to do a simple drain and refill, i.e. no flush, no dropped pan or filter change? Also, I have one quart of Castrol and three O'Reily. Can I mix and match (all are Dexron III)?
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
RobS10 is offline   Reply With QuoteReply With Quote
Old 10-02-2022, 03:45 PM #26
alumarine alumarine is online now
alumarine has a spectacular aura about alumarine has a spectacular aura about
Approximately 4 quarts.
It will be ok to use the ones you have.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is online now   Reply With QuoteReply With Quote
Old 10-02-2022, 03:48 PM #27
JoeT4R's Avatar
JoeT4R's Avatar
I got out about 4.1 to 4.2 quarts when I did a basic drain and fill, just for reference. Ymmv.
Old 10-03-2022, 12:12 AM #28
hiluxsurf1 hiluxsurf1 is offline
hiluxsurf1 is on a distinguished road
Originally Posted by 162435 View Post
Rob,
Yes sir. All maintenance/repairs/upgrades by me since day one. Just trying to get my money's worth.
Andreas
Wow for that many miles it looks amazing
2000 Hilux Surf SSR-X Millennium Silver 3RZ
hiluxsurf1 is offline   Reply With QuoteReply With Quote
Old 10-03-2022, 12:28 PM #29
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
It's best to still check the dipstick tube. It's usually 4 quarts but in one rare case I had 5 quarts come out. Not really sure why but I'm glad I checked.
326WHP 347TQ
Old 10-04-2022, 12:22 PM #30
As a secondary note, the 2WD transmission has a smaller pan and a drain/fill is about a quart less than the 4WD trans.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
atf , oil , oreilly , time , transmission
1st Breakdown... Time to pull the transmission marcus clarkus 3rd gen T4Rs 6 08-27-2020 12:34 AM
Time for the weekly transmission drain/flush question gumbii Maintenance/Detailing 1 05-28-2018 11:39 PM
Question regarding seals/brands & timing belt yella 3rd gen T4Rs 22 03-03-2018 06:44 PM
Who else will be rebuilding their engine/transmission when it comes time? OldRigNewParts 3rd gen T4Rs 40 02-08-2018 03:40 PM
What happens when it is time for a new/rebuilt transmission? xcmountain80 3rd gen T4Rs 7 11-14-2012 04:11 PM
