09-21-2022, 12:09 PM
Time for a transmission oil chance - question about brands of ATF
We have a '99 that just turned over 200K, and due for its 60K transmission oil change. I think the last time I did it I used Valvoline, but ended up with a few unused quarts of O'Reilly ATF from another vehicle. Is O'Reilly ATF a decent choice? It's the right type, and hate to dump unused ATF.
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
09-21-2022, 12:12 PM
As long as it's Dexron III it will be fine.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
09-21-2022, 12:13 PM
Real Name: Patrick
Real Name: Patrick
Whatever transmission fluid you decide to use make sure it is Dexron III compatible. If it is backwards compatible to Dexron III then you can use it. I used Dexron VI in my auto 4Runner for the 3 years I owned it without any problems. I'm sure other people will recommend some other options that they have experience with.
09-21-2022, 12:25 PM
Should be, but will definitely double check!
09-21-2022, 01:14 PM
I know Toyota does not make its own transmission fluid, but that's all I've used over the years.
Complete fluid exchange every 100k miles, and a filter change around 400,000 miles simply because I was curious (the original looked fine). The truck now has 518,000 miles and shifts the same way it did when I bought it new.
Andreas
2001 SR5 4Runner 4WD, Dorado Gold, 546,XXX 1-owner miles
2002 4Runner, Dorado Gold, 226,XXX miles
1998 4Runner, Oxidized, 265,000 miles
2014 Audi A4 quattro, Monsoon Gray
1995 Porsche 993, Polar Silver
09-21-2022, 01:20 PM
I have been using Oreilly brand for my gear oil and ATF for a long time. I wouldn't worry about it. It meets the specs. Don't overthink it.
The 4Runner Show
09-21-2022, 01:27 PM
Andreas
518K miles?? Damn, good job, think yous takes the award for highest mile 4Runner I've run across .
09-21-2022, 01:28 PM
Thanks, good to know .
09-21-2022, 02:03 PM
Rob,
Yes sir. All maintenance/repairs/upgrades by me since day one. Just trying to get my money's worth.
Andreas
09-21-2022, 04:14 PM
I think the valvoline ATF full synthetic is compatible with lots of ATF fluids. This is what the trans shop added into my 2000 LandCruiser transmission after it got its trans rebuilt.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
09-21-2022, 04:58 PM
It’s got a drain plug. Use your flavor and do it often.
I do it every 30k miles. It’s always been 4qt removed so I don’t even bother checking the pain in the arse dipstick.
I’ve been using supertech from Walmart for years.
09-21-2022, 06:51 PM
Rob,
Andreas
I'm drooling over here... sheesh!
Sent from my SM-S908U using Tapatalk
09-21-2022, 07:27 PM
Joe,
It has plenty of battle scars. But all original paint.
Andreas
09-21-2022, 07:28 PM
Yes, the drain plug is very handy, unlike my old Dodge pickup where you have to drop the pan.
