09-24-2022, 02:56 PM
#16
Originally Posted by Zhehan
The front end is pretty much where it has always been. Freshening up the front end did wonders for handling, comfort and steering precision, however. The Downey coils, before they sagged, were simply taller than the 891s.
I took out the upper metal strips that the OEM spare tire rests on. I don't fully inflate the spare since I carry a compressor. That helps quite a bit, actually. Also, I trimmed a lip off the interior of the hitch receiver. I never tow anything. I only use the hitch to carry my bikes. So, it wasn't going to cause a structural issue. I hoist up the spare with the carrier and wedge it between the upper crossmember and the inside of the hitch. Remember, don't fully inflate the tire and it will be squishy enough to compress it.
I have an old pic for illustrative purposes of the parts I removed:
See that little box protruding from the inside of the hitch? I cut that off.
Very interesting. Thanks for the photos! My spare (inflated) takes some jockeying to get into he right spot on the tread blocks.
That’s cool you can fit a 33”. I keep wanting to get a bumper with a swing out until I start think about how in the way the swing out it’s going to be most of the time and how heavy the bumper will be.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
09-24-2022, 02:59 PM
#17
For what it’s worth, Not that it helps your situation at all, but I get a really healthy amount of rake with my ome 2890 Springs. Even with a cooler, all the recovery, full of guns and everything.
Way more lift than the 2906. I wonder if the 861 would help you?
09-24-2022, 03:21 PM
#18
Ah, yeah. You’re right. I couldn’t remember if it was 410 or 420.. my bad haha. But yes, THAT ONE will work with the rears on the 3rd gen. Just don’t bust your nose like I did trying to get the damn thing in with a prybar. lol.
Reason: more detail
09-24-2022, 05:08 PM
#19
Originally Posted by JoeT4R
What do you know, here they are for sale on T4R for $85 shipped. Can't beat that!
https://www.toyota-4runner.org/for-sale-suspension-wheels-tires/307206-lc-7-5-wraps-$100-shipped-ky.html
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
09-25-2022, 03:49 PM
#20
And, Scene.
Thanks to everyone who contributed thoughts, experience and information to this thread. I really appreciate it. The wife and I just got back from a 2-day trip through the Tillamook Forest to the coast and back to celebrate our 21 years together. We spent a lot of time in this vehicle, but it had sat for a few years due to it needing the refresh I recently did to it. It was a nostalgic run. My wife even suggested the trip herself!
This was a good shakedown run for the current build of the 4Runner. We weren't heavily loaded, just a duffle bag for our clothes, small cooler for snacks and water, hi-lift jack, shovel, tools, other odds and ends, plus 2 humans. It was a fun trip.
I'm used to how the truck sits now, and the wife even called it "sexy". So, I probably shouldn't mess with it. ;-)
At any rate, I'm going to leave things as-is until next year and most likely swap out the current setup for a Dobinsons IMS.
Cheers!
Gratuitous shot from the trip:
