Old 09-25-2022, 04:23 AM #1
stevew092984 stevew092984 is offline
stevew092984 is on a distinguished road
Clicking noise while turning
So I’ve noticed a clicking noise near my front drivers side tire area when I’m turning slowly left. Any idea of what this might be. Thanks
stevew092984 is offline   Reply With QuoteReply With Quote
Old 09-25-2022, 04:31 AM #2
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a jewel in the rough JoeT4R is a jewel in the rough JoeT4R is a jewel in the rough JoeT4R is a jewel in the rough
JoeT4R's Avatar
It could very likely be your CV axles. Do you have any rips to tears in your axle boot? Any other pertinent information you can provide?
Sent from my SM-S908U using Tapatalk
2001 SR5 4WD | 320K+ | Sonoran Steel 1.2 | Build Thread
Old 09-25-2022, 07:45 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Clicking when in the at heavy turning is very classic sign of a failing CV joint. I had it full me once with a loose lug nuts. So I would thoroughly check everything out in that area then if everything else is good. Suspect the CV joint. +1 on possible CV joint issue.
Old 09-25-2022, 08:22 AM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is just really nice jgue467 is just really nice jgue467 is just really nice jgue467 is just really nice
jgue467's Avatar
Lets hope its a rock stuck in your tire...
2001 Limited 4WD - 340+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 09-25-2022, 09:47 AM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future
mtbtim's Avatar
Real Name: Tim
Another vote for a bad CV axle. The clicking is a classic sign of a worn joint. But, I've found it's usually the outside wheel on a turn is the one that will click because more pressure is on that tire. So, on a left turn, the right wheel will actually have more force being applied to it. On a right turn, the left wheel will have more force.
I'd check for wheel bearing play too. Jack up the wheel, grab it at the 12 o'clock and 6 o'clock positions and push and pull with opposing force to feel for any play in the bearing.
If you determine it's the CV axle going bad, the video below will help you out. You can skip all the rebooting and boot stretch mod because if your axle is clicking, it is done and needs to be replaced.
t
Old 09-25-2022, 11:43 AM #6
stompbox1791 stompbox1791 is offline
stompbox1791 is on a distinguished road
t
Tim, is that because of shifting weight (as we turn left, the body leans right)?
stompbox1791 is offline   Reply With QuoteReply With Quote
Old 09-25-2022, 12:48 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That is a possibility as well.. Those little stones can tick pretty good. :-(
Old 09-25-2022, 01:48 PM #8
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yes, correct. When I had a CV start clicking on a Subaru Outback, I got in a parking lot and started turning tight radius turn both directions with the windows rolled down. I noticed on a tight left turn, I could hear the right CV clicking. On a tight right turn, I heard nothing.
Old 09-25-2022, 03:30 PM #9
Thanks. Learned something new.
Old 09-25-2022, 11:39 PM #10
Does anyone know what the part number is for an oem cv axle? Was on a Toyota parts website and saw two parts listed as cv axle kits, but couldn’t tell the difference between the two. Quite a big price difference although.
Old 09-26-2022, 01:13 AM #11
t
Definitely clicking from drivers side tire area when I turn hard left
Old 09-26-2022, 08:27 AM #12
jgue467's Avatar
jgue467's Avatar
The kit is a rebuild kit, the click is here to stay, permanent damage. The kit will just keep dirt/mud out and keep it from getting worse yet click will stay.
The other is well the whole part, no more click and less change in your pocket, your choice.
Old 09-26-2022, 01:17 PM #13
What comes with the kit?
Old 09-27-2022, 09:25 AM #14
jgue467's Avatar
jgue467's Avatar
The rubber boot, clamps and grease. Lower priced kit is only one side, other is 2 sides. There are a couple rather poor images located here for an '01, dial in your MY to be sure.
FRONT DRIVE SHAFT. 2001 Toyota 4Runner LIMITED 4WD | Toyota
Old 09-27-2022, 04:19 PM #15
Zhehan Zhehan is offline
Zhehan will become famous soon enough
I bought the TrakMotive TO8043ET Extended Travel axles from O'Reilly's. My right CV was toast and there were no OEM axles available in North America. The track motive part is designed for these trucks that have been lifted. The OEM part is designed for a stock height truck.
My .02
Hope this helps.
2000 4Runner SR5 Manual Trans Federal Emissions - Tundra TRD/5100, LC 7.5 Coils/Tokico Black, JBA UCA, SPC 25945 Rear Lower Links, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, AIRAID MIT, Perfect Power SMT-5, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, 16x8 Wheels w/ 285/75 General Grabber AT2, 224K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
clicking , idea , left , noise , turning
Clicking noise when turning - but just replaced CV joints mace4runner 4th Gen T4Rs 6 01-10-2017 08:13 PM
Clicking sound when turning GX4SEVEND 3rd gen T4Rs 7 06-02-2012 01:53 AM
loud clicking noise when turning 4Runner98 3rd gen T4Rs 2 01-28-2011 02:44 PM
Clunking/clicking when turning either way ryanr623 Problems & Warranty Issues 1 09-21-2010 04:48 PM
clicking when turning wheel? otterball21 4th Gen T4Rs 7 06-28-2005 02:14 PM
