Originally posted by Big J
Now you're gonna have to make the hole that your shifter comes out of bigger and extend the shifter itself, if you have an automatic then that makes things more difficult. Once thats done, now you have to extend your steering column, I don't think I have to explain why, do I?
Well that all depends on how much lift you go for. For up to 3" lift on a 2001, the shifters are fine (linkages may require some adjustments) and the steering column is easy to extend (just put a spacer in the joint). Body lifts are easy and the available kits have all the brackets and stuff you'll need in them. Certainly no need to make any holes bigger.
