Old 09-28-2022, 01:56 PM #16
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I have 2-2.5" rear lift, and the stock rear brake hose does not appear to be in danger of being stretched ...based on seeing it up on a lift, at full droop, in the service shop.
pluton is offline   Reply With QuoteReply With Quote
Old 09-29-2022, 09:23 AM #17
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Your shocks are likely still stock length of very close. I am running OME 906's and Nitrocharger shocks. I did not need any brake line extension either, its juuust close to tight, but still has slack at full stuff or droop.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 09-29-2022, 09:27 AM #18
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by texadelphia View Post
I noticed the other day that the rubber on my front brake lines is cracked. Anyone know of a good quality brake line replacement for the front brakes? They're like $100 from the dealer and $8 from RockAuto so it seems like there must be a middle of the road option.
I’m a little late to the party, but I ordered braided steel brake hoses for the front for a 1st gen Tacoma. It eliminates the hard line at the caliper, but does require a banjo bolt and copper crush washers for the new brake line to bolt to the caliper.
Old 09-29-2022, 06:51 PM #19
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
... braided steel brake hoses for the front for a 1st gen Tacoma. It eliminates the hard line at the caliper, but does require a banjo bolt and copper crush washers for the new brake line to bolt to the caliper.
If you buy the 1st gen taco lines from Stoptech, Toytec or Wheelers they come with the banjo bolts and very thin copper washers.
I found O'Reilly's has a banjo bolt and washer kit for $4 that has thicker washers - many threads about banjo bolt being too long and not sealing.
I also found 1.5mm thick M10 copper washers on Amazon for a good price ($9 for 30)
I got my.lines from Wheelers
Just FYI if going this route for all
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 09-30-2022, 09:41 AM #20
texadelphia texadelphia is offline
texadelphia will become famous soon enough
What's the benefit of this setup? Are the hard lines a common failure point?
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 09-30-2022, 10:15 AM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
No they don't unless they rust through. Makes it easier to change brake pads and looks cool...
Now the rubber flex lines can fail by cracking and the inner rubber collapse in shutting off
Old 09-30-2022, 11:24 AM #22
Real Name: Patrick
Real Name: Patrick
I don't like the weird hard line from the caliper. It makes it awkward when removing the caliper. There was no price difference between replacing just the current brake hose and replacing the hard line at the caliper with the brake hose. Seemed like an obvious decision for me.
Old 09-30-2022, 11:50 AM #23
Makes sense. That hard line does make things awkward when doing brakes.
Does that banjo bolt work with the stock calipers or do you need TBU calipers?
Old 09-30-2022, 11:52 AM #24
Never underestimate the importance of looking cool.
Old 09-30-2022, 01:22 PM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nothing wrong with that. Pull the clup on the flex line to easily change the pads. Or you can just pull the bolt that the flex line holds to make it even easier. I mostly just remove the bolt as I think that's the fastest way to change the pads. However this just how I do it.
Old 09-30-2022, 01:47 PM #26
Real Name: Patrick
Real Name: Patrick
The banjo bolt works with my stock calipers (S13WM). I don't see why they wouldn't work with the S12WE calipers as they use the same short hard line at the caliper.
I've done both methods before, but I prefer the extra movement from the longer section of flexible hose. To each their own though and it's all personal preference. I don't remove the calipers often, but it makes a difference for me.
Old 09-30-2022, 03:23 PM #27
I removed those hardlines after installing spindle gussets and went for taco lines.
I know of 2 guys with gusseted spindles that experienced hardline failures, 1 lost brakes. JM2C
Sent from my Pixel 4 XL using Tapatalk
Old 09-30-2022, 04:43 PM #28
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I should have stated and offroading as well.. :-)
$100 , brake , dealer , front , line
Extended Front Brake line for LT MrSeth 4th Gen T4Rs 1 02-14-2020 01:45 AM
Front Brake Line stever1000 3rd gen T4Rs 21 10-16-2019 10:10 AM
Front Brake Line Mike07SE 4th Gen T4Rs 30 11-03-2018 10:24 PM
Please suggest some flexible brake hoses pendragon 3rd gen T4Rs 8 07-03-2016 11:23 AM
HELP NEEDED: Front Brake Hard Line? BamaDrewski 3rd gen T4Rs 3 05-05-2015 10:21 PM
