Old 09-27-2022, 02:43 PM #1
t4rFL's Avatar
t4rFL t4rFL is offline
t4rFL is on a distinguished road
t4rFL's Avatar
Starting Issue
01 SR5 4wd
This is not my daily and parked at a friends, so I don't see it everyday. Last few times I have driven it, no issues with a cold start up. Whenever I go and get fuel and start it, it cranks but doesn't turn over, either it will turn over on the 2nd try or if i keep on cranking it for like 15 seconds or so it will start, sometimes i hit the gas and it starts. Usually starts up fine when cold, but has occasionally given me trouble while cold as well.
Fuel pump was replaced not too long ago.
What are some things I should check, I need this issue fixed asap, traveling soon with it.
01 SR5 4x4 - 265/75/16 M/T's * OME 881/906 * Cargo Drawers * Hilux 167 Snorkel * AOR Plate Bumper/Smittybilt x20 * Custom rear bumper/swingout * full skids
06 Tundra SR5 4x4
t4rFL is offline   Reply With QuoteReply With Quote
Old 09-27-2022, 02:49 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by t4rFL View Post
01 SR5 4wd
Sounds like your evap purge valve is not sealing correctly causing fuel vapor to get pushed into your engine intake whenever you fuel up causing a rich condition that won't ignite (essentially flooding the engine) until you crank long enough to clear the extra fuel vapor out of the intake.
cold , fuel , start , starts , turn
Starting Issue j-t4r 4th Gen T4Rs 0 10-06-2015 11:31 AM
Starting issue. RoyBell 3rd gen T4Rs 2 09-25-2015 11:26 PM
Starting issue 4RunnerBabe Problems & Warranty Issues 1 02-05-2014 11:14 AM
Starting issue stevestoy Problems & Warranty Issues 9 02-18-2010 07:05 PM
starting issue 4Evr4RunN3R 3rd gen T4Rs 21 12-01-2008 01:04 AM
