Old 09-30-2022, 05:51 PM #1
CoCoCo4Runner CoCoCo4Runner is offline
CoCoCo4Runner is on a distinguished road
Differences in 1998 Federal 5VZ and "California" 1999 5VZ
Finally found a decent engine, but it's a "California" version. I did some research before buying it, seems like the major differences are the ECU and a second catalytic converter (which is not relevant to the swap and became the Federal standard anyway)
This engine came with the entire wiring harness hooked up and uncut, will I be able to use it? Or do I have to use my original wiring harness, and are there other emissions or additional sensors in this engine that isn't present in the 1998 5VZ?
Thanks!
CoCoCo4Runner is offline   Reply With QuoteReply With Quote
Old 09-30-2022, 08:02 PM #2
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
That engine will work fine, always use the wiring harness that matches the body of the vehicle the engine is going into so you’ll want to keep your original engine harness no matter what engine you swap into it
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 09-30-2022, 08:08 PM #3
The engine itself is the same. The engine/trans wiring will be different due to CA emissions (AF sensor vs. O2 sensor) and year (electric PS idle-up vs. vacuum idle-up). Swap all your '98 externals and wiring on to the '99 engine and it will work just fine.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-30-2022, 10:26 PM #4
Good to know that's what I suspected, long block is the same. Thanks all!
Old 10-04-2022, 08:14 AM #5
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
I put a 99 engine into my 97, I believe all I did was swap the harness over (put the original 97 harness on the 99 engine). Everything on the engine side was the same.
Good luck
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
5vz , differences , engine , federal , harness
Alikazam - 1998 4runner 4cyl "Betty" - Build Thread Alikazam 3rd gen T4Rs 16 08-18-2017 05:56 AM
Differences between "2009 limited" or "2010 sr5" longeuayms General Discussions 7 01-30-2014 10:16 AM
2013 4runner "the dip whip" from central California cali*roots New Members 3 07-02-2013 12:21 PM
