Old 10-01-2022, 06:38 PM #1
RidingDirty RidingDirty is offline
RidingDirty is on a distinguished road
Anyone use this rear diff cover? (Dorman 926-993)
Has anyone used this to repair their rear axle differential cover (Dorman 926-993)? Or any info on rear diff cover repair?
Differential Cover | 926-993 | Rear Differential Cover | Dorman Products
My rear axle diff cover now has pinholes from trying to weld on some DIY brake line and e-brake brackets. The rear diff cover steel was getting thin at the bracket locations, so I should have seen this coming. But I didn't and after chasing pinholes with the welder, I feel as though I have lost confidence in my rear axle's ability to retain fluid.
I know people use JB Weld, but I want a more permanent solution. Also I know people recommend the Barnes HD diff cover, but I just want an OEM style cover with the brackets and stock fluid capacity.
Toyota Pick Up Heavy Duty Differential Cover
– Barnes 4WD
RidingDirty is offline   Reply With QuoteReply With Quote
Old 10-01-2022, 06:55 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
– Barnes 4WD
I doubt that will fit on with the lateral control arm as some of those weld on covers will not clear and you dont need that crashing into your ring gear so make sure it clears everything before welding it on.
Edit :
The above its the barnes4wd cover.. The dorman should fit. I would just verify everything clears. I have seen posts and thread elsewhere . That the cover hit the lateral control arm.
Old 10-01-2022, 07:10 PM #3
What gauge wire are you using?
Old 10-02-2022, 02:46 PM #4
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Has anyone used this to repair their rear axle differential cover (Dorman 926-993)? [/url]
I welded one on yesterday. I was a little apprehensive ordering it considering the brand is Dorman but it ended up being little beefier than the stock cover. You will definitely want to remove your diff before cutting/ welding and probably remove your axle housing unless you have a lift to work under.
Anyone use this rear diff cover? (Dorman 926-993)-diff12-jpg
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 10-03-2022, 10:25 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
So the Dorman covers clear the lateral control arm. Great to know..
brackets , cover , diff , people , rear
Rear Parking Brake Return Springs and Bell Cranks - OEM or Dorman? EJosephs 3rd gen T4Rs 5 05-09-2021 09:53 PM
Dorman valve cover?? fblainen11 3rd gen T4Rs 20 05-09-2020 12:00 AM
FS: 3rd Gen Dorman Valve Cover (dr. side) plus seals, $160, Rutherfordton, NC ThrasherSOWT For Sale: T4R Items 0 12-03-2019 01:52 PM
Can I swap the innards of my rear diff with a locking rear diff from another 4runner? xx_independent_xx 3rd gen T4Rs 23 11-19-2013 11:19 PM
Rear diff armor (my way of fixing leaky rear cover) rm2fast 3rd gen T4Rs 5 02-21-2013 02:29 PM
