Old 10-05-2022, 09:57 PM #1
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Rustbelt People - Do the Panhard Bar Bolts Seize in the Collar?
As title states, my 4Runner is tail swinging just a slight bit and I would like to replace them with Energy Suspension but I would like to know first if the long bolt inside the collars seize up due to rust/age. I feel like my large Milwaukee 1/2" impact will get em out easy but I don't want to break something that's still fine. Not sure if I can just sawzall the bolts out to not waste time... not sure. Any one here successfully replace the bushings on the rusted out trucks as they age? Have a real bad experience with Hondas and bolt/collars seizing up but the Toyota rarely gets suspension worked on. Thanks.
- FD7683
2000 4Runner Limited 4x4 V6
Old 10-05-2022, 10:41 PM #2
Zhehan Zhehan is offline
Zhehan will become famous soon enough
I just replaced mine and the passenger side was seized. Driver's side was not. I cut the bolt with an angle grinder with a cutting disc. I used a ball joint press to push out the old bushings and also to install the new ones. I installed ES bushings which come with a new sleeve. I bought a new bolt for the passenger side.
2000 4Runner SR5 Manual Trans Federal Emissions - Tundra TRD/5100, LC 7.5 Coils/Tokico Black, JBA UCA, SPC 25945 Rear Lower Links, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, AIRAID MIT, Perfect Power SMT-5, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, 16x8 Wheels w/ 285/75 General Grabber AT2, 224K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 10-05-2022, 11:37 PM #3
162435's Avatar
162435 162435 is offline
162435 is on a distinguished road
162435's Avatar
I d replaced those bushings a few times over the years, both with Energy Susp. as well as Whiteline. Any fastener I remove gets cleaned and slathered in antiseize before going back (the joy of life in the Mid-Atlantic).
Andreas
2001 SR5 4Runner 4WD, Dorado Gold, 519,XXX 1-owner miles
2002 Toyota 4Runner, Dorado Gold, 216,XXX miles
2014 Audi A4 quattro, Monsoon Gray
1995 Porsche 993, Polar Silver
162435 is offline   Reply With QuoteReply With Quote
Old 10-06-2022, 09:43 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
I had really good luck with those bolts coming out. I like others will clean and anti seize them to keep it that way. I have seen ones that you think oh boy that's not moving. Come apart. What really helps is their size as the 10mm or 12mm heads bolts can easily snap.
Old 10-06-2022, 10:29 AM #5
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Commercial bolts without flange head will have larger heads, and you can just add a hardened washer
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
bolts , bushings , replace , seize , suspension
Skid Plate Bolts - anti-seize, thread-locker, nothing? rageandlove 5th gen T4Rs 7 05-23-2021 11:15 PM
Panhard Correction Kits for the 4th gen - fix that panhard bar angle! eimkeith 4th Gen T4Rs 109 01-08-2021 04:21 PM
Rustbelt 07 4Runner Tailgate handle repair Snagglepus 4th Gen T4Rs 2 12-22-2020 03:21 PM
Loctite blue or anti-seize paste for skid bolts? Tallman 5th gen T4Rs 16 12-19-2018 04:47 PM
white collar, blue collar slimjim Polls 35 05-10-2016 10:31 PM
