08-23-2022, 10:34 PM
Real Name: Robert');DROP TABLE Students;
12voltguy still in business?
I melted my elocker harness and need a new one, but his websites are all jacked up and he’s not responding to emails. Anyone know if he’s still in business?
Any other recommendations for an elocker retrofit harness?
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
08-25-2022, 12:00 PM
Real Name: 3 Bears
Real Name: 3 Bears
make it yourself, I did this with my first 2000 which was a retro fit
How To: DIY 3rd Gen 4Runner 8" Retrofit Elocker Wiring
08-25-2022, 12:42 PM
yota masters has a harness i used for e locker plug and play
08-25-2022, 02:06 PM
Real Name: Mark
Real Name: Mark
This is what I used to construct my harness.
08-25-2022, 04:51 PM
Real Name: 3 Bears
Real Name: 3 Bears
another advantage of not using the factory system is that you basically make the "gray wire mod" allowing you to use the locker even in 4wd high or even just 2 wheel drive. i use prob more often in 4wd high. kick in when when needed and no reason to kick into 4 wd low. good for my roads/conditions as i can just slow way down.. and still be moving and kick on the locker without stopping to switch to 4wd low ( i have a j shift) and more often than not just kicking on the locker gets me home....not needing low range.
disadvantage...well a wire yourself wont light up on dash board like a factory unit will. so use a lighted rocker switch and be aware of what you are doing/driving.
if you go with a factory system and replace computers etc....id still do the gray wire mod. My current rig is factory elocker and with the gray wire mod my dash lights up regardless of if 4wd low, 4wd high or 2wd...when engaged of course
08-25-2022, 08:09 PM
Real Name: 3 Bears
Real Name: 3 Bears
maybe you should change your thread....or start a new one..retro.elocker wire harness help ?
08-26-2022, 04:50 PM
Well, I'd like to just buy a new harness rather than making another one, because I gotta buy all the tools and materials to make a new one.
08-28-2022, 08:39 AM
I was swamped on Friday and didn't have time to type out a full response:
For clarification, I've been using a 12voltguy harness for a few years - I just destroyed it when I ripped my exhaust off and melted a bunch of stuff under the 4Runner.
My issue with making my own is that the smallest available length of cable he used (Honeywell Genesis 1121 18/8c) comes on a 250' spool and it costs twice what his entire kit did. Then I gotta buy de-pinning tools, pin crimpers, more snake skin, vent tubing, etc. It'd end up being $400+ and many hours of harness fab that I just don't have.
Unfortunately, it looks like Yotamaster's retrofit kit is just about that much...
08-28-2022, 09:18 AM
Real Name: Mark
Real Name: Mark
@ thezentree
, Have you considered splicing new wires for the burnt section ?
Solder iron, solder, heat shrink tubing, wire, time would be minimal couple hours at the most.
08-28-2022, 11:11 AM
Real Name: Patrick
Real Name: Patrick
The yota masters is for the whole kit. Might be worth contacting them for just the harness that you need.
08-28-2022, 12:20 PM
Originally Posted by 96RedRunner
@ thezentree
I have, and have a bunch of solder sleeves I could use, but I want to use the same cable as the rest of the harness so I’d end up having to buy a roll of that cable anyway.
Originally Posted by Bad Luck
The yoga masters is for the whole kit. Might be worth contacting them for just the harness that you need.
Good point, I’ll shoot them an email!
08-28-2022, 12:30 PM
Originally Posted by brillo_76
That's not a bad idea to replace the damaged wires and rebuild it. Could be just doesn't have enough time to do that and looking more for a simple plug and play solution.
This is where I’m at. I just bought a house and am remodeling it while working full time and doing an engineering masters degree. I get a couple hours a month to do 4Runner stuff these days…
08-28-2022, 01:19 PM
Real Name: Mark
Real Name: Mark
Food for thought, Honeywell Genesis 1121 18/8c is standard 8 conductor A/C Thermostat wire,
hit up a A/C service guy bet you could get what you need for cheap off the service truck.
Do understand the time constraints do without sleep for a night have more money for remodel. J/K
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
