Old 10-06-2022, 12:04 AM #1
Mada89 Mada89 is offline
Mada89 is on a distinguished road
Hesitating and Lurching when Accelerating or Decelerating
Have a 98 4runner, manual transmission, and it has been hesitating when accelerating and lurching when I take my foot off the gas. Just replaced the plugs, wires, and coils and it was fine for about a day and then it came back. Thoughts on what to check next? No CEL. Normal idle. Seems to come on after it warms up and lightly at first then seems to get worse. Sometimes seems to go away though. Acceleration is fine once it does go but is a heavy thump, likely the drive shaft maybe when it does finally accelerate.
A few weeks back replaced:
- fuel pump
- fuel filter
- alternator
- power steering pump
- belts
- water pump
- timing belt
- thermostat
- oil/filter
- coolant
Past few days replaced/did:
- plugs
- wires
- coils
- 1 can of fuel system cleaner in the gas tank
- MAF sensor cleaned with MAF cleaner
- air filter
- felt/looked at vacuum lines and all look good at least
Appreciate any thoughts!
Mada89 is offline   Reply With QuoteReply With Quote
Old 10-06-2022, 09:14 AM #2
spartacus's Avatar
spartacus's Avatar
TPS sensor could be going out.
Old 10-06-2022, 09:39 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What your fluids as to rule out a coolant leak into the cylinder as a possibility..;)
Old 10-09-2022, 11:57 PM #4
Thanks both. Fluids look good. I replaced the TPS and tightened the throttle cable and sprayed wd40 on the springs on it. It seemed looser than it should be and saw in another thread that it could be the issue. Seems to have fixed it as it hasn't done it since I made those changes. Fingers crossed it doesn't come back!
Old 10-10-2022, 08:06 PM #5
Replacing the plug wires solved this issue on the Puppy Hauler.
I had perfect wires and my issue was a bad boot on a coil. Under load it brake down and cause a missfire.
Old 10-12-2022, 11:31 PM #6
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I also had lurching and a surging idle when taking the foot off the gas. It was the TPS, no codes. It is a silent issue and can be baffling until you narrow it down. Sorry you had to try so much before you found it!
326WHP 347TQ
Old 10-15-2022, 11:21 AM #7
BretMann BretMann is offline
BretMann is on a distinguished road
Could be clogging fuel injectors. Try a good fuel cleaner with PEA (polyetheramine) like from Gumout or their fuel injector cleaner. If it gets better, that's probably your problem. You can send them off to RCFuelinjection.com for testing and pro cleaning for I think it was about $20 each injector. They give you a before/after performance report.
Bret
1999 4Runner(3rd Gen) Base, Engine: 2.7L (3RZ-FE), Trans: 5sp manual (W59)
Miles as of 10-2022: 107k
VIN: JT3GM84R2X0047863
BretMann is offline   Reply With QuoteReply With Quote
cleaner , fine , fuel , hesitating , pump
Clicking sound while decelerating? Robb235 3rd gen T4Rs 23 02-24-2021 10:13 PM
Shaking when decelerating to a stop? OdinWiski 4th Gen T4Rs 31 02-11-2020 11:19 PM
Vibration/growling when decelerating? Freb_mc Classic T4Rs 24 01-12-2015 08:31 PM
Humming sound when coasting-decelerating (05 V8 4x4) BzJeep 4th Gen T4Rs 8 12-05-2013 02:22 PM
Skippping and hesitating Tiki 420 Problems & Warranty Issues 3 09-27-2010 08:33 PM
