Old 10-10-2022, 04:32 PM #1
hellcat287 hellcat287 is offline
hellcat287 is on a distinguished road
Need a Mechanic - Las Vegas area
Noticed a rear axle seal leak about a week ago. I replaced the seal itself about nine years ago from a previous leak and it held up this whole time.
At this point I think I should just replace everything on the axle as my rig has over 240K and I'm sure the bearings, races, etc. are original.
Looking for a good mechanic in the Las Vegas area who can either R&R the whole thing OR I can bring them the axle and have them remove / replace the bearing, races, etc.
Thanks!
hellcat287 is offline   Reply With QuoteReply With Quote
Old 10-10-2022, 04:42 PM #2
Grgg1978's Avatar
Grgg1978 Grgg1978 is offline
Real Name: Greg
Grgg1978 is on a distinguished road
Grgg1978's Avatar
Real Name: Greg
Thanks!
I usually take my 4Runner to Corey at battle born diesel.
Greg Gonzalez-Realtor-Keller Williams Realty Southwest
-Direct- (702)302-3646
-Email- [email protected]
-Website- GregSellsVegas.Com
-99 4runner 3.4 5spd SR5 4x4 locking differential, 231 tundra brake upgrade, breather mod.
Grgg1978 is offline   Reply With QuoteReply With Quote
Old 10-10-2022, 04:54 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks!
If your rear diff isn't making any extra noise then I would just replace the rear axle seals, retainers, and wheel bearings and call it good.
Old 10-10-2022, 06:06 PM #4
That was my plan. Not going to touch the actual diff.
Old 10-10-2022, 06:22 PM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You could be the mechanic if you have the time, space and willingness to do the work. Not having the tools isn't a good excuse because the money you save doing your own work will quickly pay for the tools.
Just so you know, the rear axle seal/bearing job has got to be one of the most common jobs for these rigs that the paid guys screw up. That's auto mechanic shops and machine shops.
You should watch these videos to learn about the job so you can better select a shop to do it. With the knowledge I share, you can question the people doing the work to figure out if they know what they're doing or they are hacks.
t
Old 10-12-2022, 01:34 PM #6
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough turbo8 will become famous soon enough
turbo8's Avatar
Try Dan's Driveline
5650 W Duncan Dr, Las Vegas, NV 89130
+17026585650
Dan's Driveline
I have brought in axles with all the parts and they did all the press work. Turn around time was a day.
I think it was around $75 an axle for the press work, which was worth it for me.
Try partsouq for real cheap OEM parts.
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 07:20 PM #7
Mgyver1's Avatar
Mgyver1 Mgyver1 is offline
Mgyver1 is on a distinguished road
Mgyver1's Avatar
Adam’s Driveline did the press work on my rear axles when I replaced the seals & bearings. They did the press work perfectly as I measured it before & after their work.
Dan’s Driveline did my gears when I had4.88’s put in. They did good work, only a couple of minor complaints. They didn’t tighten the rear diff drain bolt (it was finger tight, but it’s better than being over-tightened I guess), and they also left some bailing wire around the front drive shaft, but it wasn’t making any noises or anything. It’s been many thousands of miles now and the gears are going strong.
For other maintenance stuff I would go to Wally’s Precision. They only do Toyota/Lexus & Honda/Acura.
2000 Limited. Lifted....finally!
www.OverlandNV.com
Mgyver1 is offline   Reply With QuoteReply With Quote
ago , axle , leak , races , replace
ISO mechanic in Seattle area sntryplt General Discussions 5 03-28-2022 11:49 PM
good toyota mechanic in las vegas, don't trust dealership rockwind1 General Discussions 8 07-11-2020 10:39 AM
Need a mechanic in Bay Area, CA latosf 4th Gen T4Rs 7 12-02-2016 10:25 AM
Best 4Runner mechanic in Las Vegas? skywalker1020 General Discussions 0 12-02-2011 01:20 PM
