Old 10-27-2022, 09:53 PM #16
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by Jidaran View Post
I can't drain the oil right now to see what it looks like due to a stripped drain plug, but it's clearly got enough in there, so I'm good, right?
Sounds like you could use this video for ideas on how to get that stripped drain plug out. When you finally get it out, don't use a ton of force to put the new one in. If you ever have a hard time getting one out again, heat is your friend. Heat up the differential around the plug, not the plug itself. The heat helps break the bond of the copper washer with the diff and drain plug. With the proper application of sufficient heat, you'll never strip one of these drain plugs again.
Lexus makes a plug that fits our differentials that has a regular hex head rather than an allen head. Lexus hex drain plug #90341-24016
t
Old 10-28-2022, 02:20 PM #17
Jidaran's Avatar
Jidaran Jidaran is offline
Jidaran will become famous soon enough
Jidaran's Avatar
I did give that method a shot but didn't have any luck. I may try again before giving up and going to a shop, but it's hard in the city with no off street parking... Thanks for the info on the Lexus plug though, gonna order a few of those and avoid this problem all together in the future.
2002 Limited 4Runner
2001 Jeep Cherokee
Jidaran is offline   Reply With QuoteReply With Quote
Old 10-28-2022, 02:22 PM #18
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I used a chisel to cut a shallow groove in the plug face at 5:00 then hammered it off
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-29-2022, 12:50 AM #19
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If it's not totally stripped out and you can still get a decent bight with the allen socket, you should be able to get it off with sufficient heat. Heat up around the plug for around 30 seconds to a minute and give it a shot. If it still won't budge, give it another 30 seconds of heat and keep doing that until the plug gives with moderate force.
If it's stripped out completely, try the chisel method @octanejunkie mentioned.
Or, you can weld a nut on. I bet a muffler shop would do it for you for no more than $20.
Old 10-29-2022, 10:59 AM #20
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
This for sure.
You can even try to hammer a torx bit in. Anything that will bite. I have an impact driver set for this sort of thing, and one thing I’ve done the pass is fined a flat head bit that can just barely get wedged in. Then take the impact driver and a hammer. Pop loose every time.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 10-07-2023, 10:59 AM #21
PENOBSCOT PENOBSCOT is offline
PENOBSCOT is on a distinguished road
I just got a message back from Joey and he has 80 of them headed to his anodizer. He gave me an ETA of 2 weeks.
Appears, these are still on back order. Anyone in the Spokane/North Idaho area has one they would like to rent out.
PENOBSCOT is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 08:53 PM #22
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The simplest way I found out to get a stripped 10mm Alan hex plug out is to use a t55 torx impact bit. Hammer it in, and the plug will come out. After a replace the plug , I cover the head in mp grease so I never have issues again.
I am looking for the replacement aluminum crush washers in all these diff plugs in copper as if they are flat and the proper dimensions. You can reuse them forever. As both copper and aluminum flats are perfect for reuse. I don't care for the single use washers myself. Seems wasteful to me.
Old 10-09-2023, 09:08 PM #23
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I recently found out ECGS sells one. They have it offered as an addition to bushing installer, but I bet if you call them, they will sell it separately to you. When you call, tell them Timmy the Toolman says Hi.
T7.5 & T7.5 Clamshell Bushing Installer Tool
Old 10-10-2023, 10:41 AM #24
That link allows you to buy the tool separately
Old 10-10-2023, 11:46 AM #25
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You're better than me. That page I linked looks like you can only buy the seal driver puck as an addition to the bushing driver. I couldn't figure out how to buy it on its own.
Old 10-10-2023, 12:57 PM #26
Maybe I didn't understand the assignment, I'm rarely better than anything lol
The description says:
Specially designed tool for installing the 7.5 bushing into the housing. Bushing pilots onto tool to ensure bushing is driven flush.
Also with the option to add the seal installer puck. This puck is designed so that the lip of the seal fits into the indent of the puck to ensure the seal is driven flush.
The puck can be added for $15 more
Old 10-14-2023, 02:03 PM #27
Great information, thank you for the help.
Old 10-17-2023, 06:00 PM #28
@mtbtim what's the best way you've found to install the outer CV dust shield 90080-30028 on the CV axle?
Old 10-18-2023, 05:30 PM #29
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Just gradually tap it in place with a brass drift or punch. It doesn't require much force to seat it onto the axle.
Old 10-22-2023, 08:35 PM #30
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Today I learned that this is a replaceable part, which means I can salvage the CV I've been saving as a core rather than messing with a torn boot on another one.
Saved me a hundred bucks, thanks for that.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
axle , changing , numbers , part , seals
Anyone in SD/OC that can help with rear axle seals? APhelps So Cal 4 03-20-2019 01:14 AM
Q: Replace axle bearings&seals or find assembled axle? Mutant 3rd gen T4Rs 12 09-14-2017 10:35 AM
96 rear axle seals brad7410 3rd gen T4Rs 3 11-07-2009 02:47 PM
Axle seals shawnstcyr 3rd gen T4Rs 6 06-04-2009 10:47 PM
Axle Seals Kramer420 3rd gen T4Rs 1 05-25-2005 11:16 AM
