Old 10-12-2022, 09:11 AM #1
RobS10's Avatar
RobS10 RobS10 is offline
RobS10 has a spectacular aura about RobS10 has a spectacular aura about
RobS10's Avatar
Another Fluids Question...
I did my transmission oil change successfuly and on to the transfer case...more oil on hand from a previous vehicle is 80-90W gear oil...the manual calls for 75-90W. Is 80-90W OK?
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
RobS10 is offline   Reply With QuoteReply With Quote
Old 10-12-2022, 09:53 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
80W90 is fine
Old 10-12-2022, 09:58 AM #3
JoeT4R's Avatar
JoeT4R JoeT4R is online now
JoeT4R is a jewel in the rough JoeT4R is a jewel in the rough JoeT4R is a jewel in the rough JoeT4R is a jewel in the rough
JoeT4R's Avatar
Originally Posted by Bad Luck View Post
80W90 is fine
+1 on it being fine. Rear diff and t-case both call for 75W-90 but I recently (earlier in the spring?) filled my rear diff with 80W-90. No adverse effects so far. You're good. Use full syn gear oil @ OP.
2001 SR5 4WD | 320K+ | Sonoran Steel 1.2 | Build Thread
JoeT4R is online now   Reply With QuoteReply With Quote
Old 10-12-2022, 08:15 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future
mtbtim's Avatar
Real Name: Tim
I was using 75w-90 Redline full synthetic gear oil for both diffs and the transfer case, but after filming the videos we made with East Coast Gear Supply, I'm now going to be running Lucas 85w-140 Non-Synthetic in both diffs. This is what ECGS recommends.
Amazon.com: Lucas 10045 Heavy Duty 85/140 Gear Oil - 1 Gallon : Automotive
Old 10-12-2022, 10:37 PM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is a jewel in the rough LittleCaesar is a jewel in the rough LittleCaesar is a jewel in the rough LittleCaesar is a jewel in the rough
Transfer should be 75w90- been running Mobil Delvac with good success. Also use in the front diff.
Rear diff gets Mobil HD 80w90.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 01:52 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Tim, It'd be interesting to know if the 85w-140 leads to lower mileage and/or slower acceleration once you switch. I once put Mobil 1 75W-140 in the rear diff on a 4 cyl 4WD Toyota truck, and I could easily tell that acceleration was slowed down a bit.
Also, how long will your change interval be on the rear diff?
pluton is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 02:48 AM #7
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I plan on changing my diff gear oil at 10k intervals.
I imagine the thicker gear oil could lead to a drop in mpg. My truck even with the re-gear to 4.88s is still a slug because of how heavy I am with the bumpers, full belly skids and roof rack.
Old 10-13-2022, 03:59 AM #8
19963.4lsr5 19963.4lsr5 is online now
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
I didnít notice anything on my 96 with the 3.4
19963.4lsr5 is online now   Reply With QuoteReply With Quote
75-90w , 80-90w , calls , hand , oil
Fluids thatoneguygeoff 3rd gen T4Rs 3 11-02-2015 10:03 AM
Toyota Fluids vs. Aftermarket Brand Fluids chayos00 Maintenance/Detailing 22 12-30-2014 02:12 PM
Fluids question kfroemmi 4th Gen T4Rs 3 07-27-2013 04:17 PM
fluids! RpzInc Classic T4Rs 2 06-05-2011 01:32 AM
Fluids- what synthetic engine oil? Trans fluid question- PAULUNM 4th Gen T4Rs 1 08-31-2008 02:17 PM
