Old 10-13-2022, 02:47 PM #1
RunningForNow RunningForNow is offline
RunningForNow is on a distinguished road
Clunking Noise from Driver's Side Front Wheel (VIDEO)
Got a clunking noise coming from the driver's side front wheel whenever I go over a speed bump, pothole, or any uneven surface. I shot a video on my GoPro but couldn't find any anomaly when I drove around the block.
Bilstein 5100s and OME 880 springs are less than 3 years old with less than 10k miles. LBJs are replaced in the last year. LCA and UCA are OEM.
Here's the link to the video, ignore the first 30 seconds: Front Wheel Clunk - YouTube
RunningForNow is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 03:12 PM #2
nissanh nissanh is offline
Sounds like a loose bolt/nut, Do you have the metal plate ("t" shaped) and "W" shaped spring holding the brake pads tight?
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 10-13-2022, 03:17 PM #3
Sparman Sparman is offline
Real Name: Curt
Sparman is on a distinguished road
Real Name: Curt
Could you post some pics of the alignment cams on the lower arm?
Sparman is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 03:57 PM #4
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold Devbot is a splendid one to behold
Devbot's Avatar
Real Name: Devan
I highly doubt it because OME coils aren't as thick, BUT with my Tundra coils I had a clunk for a while that I couldn't find whatsoever before it mysteriously went away. Then last month when switching to Toytec/Eibachs I found out the drivers side coil was just barely kissing the UCA bolt sleeve during its compression, and the noise disappeared because after some time the coil wore a flat spot on the sleeve and clearanced itself. Like I said it's probably not the cause but it wouldn't hurt to pull the strut and check it out if you can't see back there already.
Y2K Highlander Millennium Silver 3.4L auto @ 300k and climbing
Toytec + 5100s / 210v + Tokicos / JBA UCAs / Anonymous Fab. LBJs / Total Chaos Gussets / EimKeith PCK + LCAR / Extended Bump Stops; Brake Lines; Rear Diff Breather / True North Fab. Hybrid Bumper / CBI Hybrid Bumper + Tire Carrier / 4xInnovations Hybrid Sliders / Smittybilt XRC Gen 3 Comp. / Opt Offroad Trailing Arms / Lil Skip Gas Skid / BudBuilt Front Skid
Old 10-13-2022, 05:44 PM #5
Zhehan Zhehan is offline
Zhehan will become famous soon enough
My money is on the upper ball joint. That was my issue
2000 4Runner SR5 Manual Trans Federal Emissions - Tundra TRD/5100, LC 7.5 Coils/Tokico Black, JBA UCA, SPC 25945 Rear Lower Links, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, AIRAID MIT, Perfect Power SMT-5, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, 16x8 Wheels w/ 285/75 General Grabber AT2, 224K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 10-14-2022, 03:56 PM #6
BretMann BretMann is offline
BretMann is on a distinguished road
If you can lift the truck where that wheel is off the ground, take a crowbar or 2x4 for leverage and use it under the tire to create a simulated bumpy road. Better if some else does that, while you listen for where the clunk is coming from.
Bret
1999 4Runner(3rd Gen) Base, Engine: 2.7L (3RZ-FE), Trans: 5sp manual (R150)
Miles as of 10-2022: 107k
VIN: JT3GM84R2X0047863
BretMann is offline   Reply With QuoteReply With Quote
Old 10-14-2022, 09:44 PM #7
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Loose brake shield
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 10:30 AM #8
Currently on a business trip, but will do so when I get back.
Old 10-18-2022, 10:30 AM #9
Originally Posted by octanejunkie View Post
Loose brake shield
I checked that, and it was nice and solid. Not wiggling at all.
Old 10-18-2022, 10:36 AM #10
Tbh I can’t recall since I did the TBU 4 years ago. The pads are still at around 70%. I think given the time since they were installed, I should probably replace my brakes soon, so I’ll be sure to check. I have always put the shims and anti-squeal clips in, and I didn’t see either one of those parts hanging loose.
clunking , front , noise , video , wheel
Noise behind the rear wheel driver's side. calcrc 5th gen T4Rs 10 08-16-2020 05:24 PM
Front end driver side noise. plcfcng 3rd gen T4Rs 0 04-15-2019 12:33 AM
OW Lift on - Noise from driver side wheel area - help muddyYota 5th gen T4Rs 3 12-31-2010 06:27 PM
Clicking noise on the front driver side wheel Juank303 Problems & Warranty Issues 1 07-13-2009 01:08 AM
Thumping noise under front driver side 4runny 3rd gen T4Rs 4 01-04-2008 12:27 AM
