Old 10-14-2022, 10:26 PM #1
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
3rd Gen 4R stiff steering after start during cold temps
Hello,
Temps are between 40 and 50 degrees and I'm getting stiff steering after start up while warming up the truck. Once warm and then turning the wheel from left to right vigorously it seems to slowly go away. Truck is a 1999 with 225,004 miles.
I did a power steering fluid flush last summer 2021.
Any feedback is greatly appreciated
Thank you
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 10-14-2022, 11:39 PM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
When you did the flush, did you clean the screen in the reservoir? Also, did you use power steering fluid or ATF?
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 10-14-2022, 11:43 PM #3
ATF DEX 3. cleaned the screen with it attached the best I could. Maybe I should remove the pump from vehicle, clean on the bench and shine the flashlight through. It did not have this problem in the summer months though
Old 10-15-2022, 10:25 AM #4
BretMann BretMann is offline
BretMann is on a distinguished road
Can you get it pressure tested?
Bret
1999 4Runner(3rd Gen) Base, Engine: 2.7L (3RZ-FE), Trans: 5sp manual (W59)
Miles as of 10-2022: 107k
VIN: JT3GM84R2X0047863
BretMann is offline   Reply With QuoteReply With Quote
Old 10-15-2022, 12:18 PM #5
I would try the screen cleaning since it pretty easy and cheap. You don't have to pull the pump off to clean the screen, just the reservoir and its bolted on to the pump. There's a few write ups on here and a few videos on YouTube on how to do it if you look for them.
Old 10-15-2022, 12:18 PM #6
pressure test the power steering pump? Im not sure how to do that? Any tips?
Thanks
start , steering , stiff , temps , truck
Whistling sound in cold temps DK327 3rd gen T4Rs 4 01-31-2022 05:40 PM
Brake issue and stiff steering on startup in extreme cold? thegipper 3rd gen T4Rs 24 01-01-2017 11:55 PM
Replace u-joint on steering linkage to fix stiff steering? sibanez 4th Gen T4Rs 2 09-30-2014 08:28 AM
cold start power steering whine twicepipes 3rd gen T4Rs 15 04-13-2014 10:26 PM
Power Steering some noise during cold start hyperthread 4th Gen T4Rs 1 10-22-2010 11:01 PM
