Old 10-14-2022, 10:36 PM #1
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
3rd Gen 4R slight engine vibration during idle
Hello,
I've recently been feeling a vibration that seems like it is coming from engine bay. Truck idles at 1200 when started, then rests at about 700 once warm (takes about 10 min). The vibration seems to be present after the truck warms up and idles around the 700-800rpm range. If I turn on heat/fan, the idle jumps to about 850-900 and the vibration goes away. With the foot on brake and truck in Neutral or reverse or even moving slowly, the vibration is still there. Seems like it goes away only at higher rpms..
I checked the engine mounts by looking under hood from driver seat method and they seem ok. I will check trans mount tomorrow. Any other suggestions is greatly appreciated.
Thank you
1999 4Runner SR5, 3.4L 5VZ-FE V6, 190K
1993 4Runner SR5, 3.0L 3VZ-E V6, manual (sold)
1995 MR2 2.2L 5S-FE 4cyl (sold)
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 10-15-2022, 03:58 AM #2
19963.4lsr5 19963.4lsr5 is online now
Originally Posted by hawkcharmer View Post
Hello,
Thank you
When was your last tuneup?
Did you run a good injector cleaner lately? Techtron, Gumout, and amsoil are my go to’s.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 10-15-2022, 10:16 AM #3
BretMann BretMann is offline
BretMann is on a distinguished road
It could be your injectors. If the cleaners don't work you can send them to RCFuelinjection.com to check and clean.
Bret
1999 4Runner(3rd Gen) Base, Engine: 2.7L (3RZ-FE), Trans: 5sp manual (R150)
Miles as of 10-2022: 107k
VIN: JT3GM84R2X0047863
BretMann is offline   Reply With QuoteReply With Quote
Old 10-15-2022, 11:27 AM #4
spartacus's Avatar
spartacus's Avatar
Cleaning the maf and testing it for resistance also vacuum leaks could help
Old 10-15-2022, 12:25 PM #5
The last tune up was about 4 years ago. The plugs and wires still look good. I ran some STA-BIL through early spring 2022 and I remember it dying out at a stop sign. It quickly started back up though. The engine has 225,000. I believe that it needs a new steering rack. I also have a box here full of new plugs, VC gaskets, pcv, etc... all oem and just waiting for the right moment to put on. I just hope that no engine problems are starting.
Old 10-15-2022, 12:56 PM #6
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
If you're going to do VCGs then the injectors will be readily accessible
Check the fan clutch before tearing in
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-15-2022, 08:11 PM #7
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
A slight miss may be a loss of compression. While it can get so extreme that it may necessitate replacing I don't think you are anywhere near that. My original engine had 60 PSI and 100 PSI in two of the cylinders (150 in the rest) and it missed pretty bad at idle but ran strong for years. Loss of compression is a normal issue to have as an engine, from any vehicle, starts to rack up the miles.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 240K miles.
326WHP 347TQ
Old 10-16-2022, 08:51 PM #8
162435's Avatar
162435 162435 is offline
162435 will become famous soon enough
162435's Avatar
FWIW, I dump a bottle of Techron into my tank, 2 or 3 times per year. I've been doing this since buying my '01 new. The fuel injectors have never been touched and now have about 519,000 miles on them.
My engine tends to have a hint of a stumble at idle, but nothing that in any way concerns me given the age/mileage. Apart from all of the other maintenance, I replace the air filter (Toyota) & spark plugs (NGK BKR5EKB-11) every 25,000 miles.
I need to put another shopping list together for my 3rd timing belt job coming up soon.
Andreas
2001 SR5 4Runner 4WD, Dorado Gold, 519,XXX 1-owner miles
2002 Toyota 4Runner, Dorado Gold, 216,XXX miles
2014 Audi A4 quattro, Monsoon Gray
1995 Porsche 993, Polar Silver
162435 is offline   Reply With QuoteReply With Quote
engine , idle , idles , truck , vibration
slight engine vibration on occasion, V8 Jasonredwood 4th Gen T4Rs 0 06-05-2017 03:35 PM
Slight vibration just started ATOYOT4R 5th gen T4Rs 8 10-31-2014 11:21 AM
97 T4R 4x4 190k Automatic engine vibration at idle in gear Stretch1100 3rd gen T4Rs 30 02-27-2014 03:26 PM
'01 with slight vibration Fjatheart 3rd gen T4Rs 12 10-31-2012 03:01 PM
Engine Vibration @ Idle? MAC4Runner Problems & Warranty Issues 1 10-11-2004 07:39 PM
