Old 10-17-2022, 10:03 AM #16
JohnMc JohnMc is offline
JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light JohnMc is a glorious beacon of light
Originally Posted by Sparky 97Runner View Post
First try bleeding your master with plunger in original location. That's the easiest thing to do but you need two people. Or use a russell speed bleeder.
/\ /\ /\ If the push rod is set too long, which it sounds like was done here, then the master cylinder can't pull more fluid in from the reservoir. There is a small opening from the reservoir into the master cylinder bore that is opened only when the piston comes all the way out, as far as it can go. If the rod is too long, it won't let the piston come out far enough, and that hole stays covered, and the system can only use the fluid that's currently in it, sort of the same thing as having an empty reservoir.
Shorten the rod until it barely comes off the piston with the pedal all the way up. No need for a large gap, just a tiny bit of pedal travel needed before the rod hits the piston in the master cylinder.
SS 3" suspension lift/1" body lift/32" tires/'Snowflake' TRD Taco wheels/231mm Tundra brakes/bumpers/armor/sliders/winch/Sherpa Matterhorn rack
In progress: Manual front hubs and NWF Eco-crawler transfer case doubler
JohnMc is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 10:19 AM #17
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future mtbtim has a brilliant future
mtbtim's Avatar
Real Name: Tim
I suspect you didn't properly bleed the system. Bleeding the clutch hydraulic system can be a pain.
This video helped us get the system bled when we were doing a 3.0 to 3.4 Swap on a 2nd Gen 4runner.
clutch , extend , miles , plunger , shifter
FSM for clutch replacement northernT4R 3rd gen T4Rs 0 02-26-2014 09:46 AM
Clutch Replacement toeheadskater 3rd gen T4Rs 16 12-28-2013 06:45 PM
Fan clutch replacement.. 77'911 Classic T4Rs 0 03-01-2013 09:47 PM
AC Clutch Replacement eplanajr 3rd gen T4Rs 2 12-26-2012 07:49 PM
clutch replacement jmcgahran 3rd gen T4Rs 6 12-11-2011 04:32 AM
