Old 10-16-2022, 10:31 AM #1
BretMann BretMann is offline
BretMann is on a distinguished road
3rd Gen. 4 cyl. (3RZ-FE), valve springs issue?
I heard that the 3RZ-FE engine has a known issue with the valve springs, where they begin to fail at about 130k miles. Is this true and if so:
1- Was it factory fixed and is there a model number or date to identify which trucks this effects.
2- If not factory fixed, is there a dealer recall?
3- If neither factory or dealer fix recall fix, would a DIY fix mean removal of the head to replace them?
4- What is the correct updated replacement part No.?
Thanks.
Bret
1999 4Runner(3rd Gen) Base, Engine: 2.7L (3RZ-FE), Trans: 5sp manual (W59)
Miles as of 10-2022: 107k
VIN: JT3GM84R2X0047863
BretMann is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 01:11 PM #2
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Never heard of this issue. But the 3RZ does tend to burn valves if the lash is never adjusted. The 5VZ can typically get away without an adjustment.
JZiggy is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 03:09 PM #3
I thought you guys would know about it since I heard it was a known issue. So I went down the rabbit hole now and found it here:
Our Toyota’s Engine Has a Serious Problem & Expensive Problem | Now What? Baby Yota Ep.8 - YouTube
It's about a 2002 Tacoma with the 2.7l engine - same as mine? At 2:30 the mechanic explains the issue with the valves (not the valve springs as I stated). At 4:20 it shows a glimps of what I think is the engine label that shows X3R-N84.
Bret
Old 10-16-2022, 06:49 PM #4
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Like JZiggy said, these engines had problems with burnt valves. I've never heard of the valve spring issue.
I think I've viewed the video you linked a while ago (can't listen, at library), if I remember correctly they're referring to the burnt valve issue. And they recommend getting the valves adjusted, same thing you do to avoid burnt valve.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 12:59 PM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
The Tacoma has a different engine, the 2RZ. We have the 3RZ, or the 2.7L engine. Any engine can benefit from some regular maintenance including valve clearance adjustments. It's not a ticking time bomb though.
Careful about searching the internet. If you search long and hard enough you'll find critical, life-threatening issues on your vehicle for parts it doesn't have that you never knew existed. It's like searching WebMD when you have a sore throat and come back thinking you now have throat cancer.
326WHP 347TQ
dealer , factory , fix , fixed , recall
Valve Cover Gasket Issue? nwebb01 3rd gen T4Rs 5 09-10-2017 07:26 PM
2002 T4R IAC valve issue Icychap 3rd gen T4Rs 0 05-01-2015 03:42 PM
P0440: Fuel Cut Off Valve Issue Crazed710 3rd gen T4Rs 0 12-26-2014 09:10 PM
PCV valve vacuum line issue USSEnterprise 3rd gen T4Rs 3 05-21-2012 11:22 PM
Transmission Solenoids/Valve Body Issue? twosocks Classic T4Rs 2 03-17-2011 09:21 PM
