Old 10-16-2022, 07:17 PM #1
pdspen pdspen is offline
pdspen is on a distinguished road
Spark plug wear
Just changed spark plugs on 99 SR5, 5VZ 325,000mi and noticed that the left bank of plugs (wire side) had worn much more than the right bank (coil side).
Plugs were NGK Platinum and had been in the vehicle for a little over 60k of hard miles. (Plenty of towing including 2 cross country trips pulling around 6k. [Proper coolers, air bags and WD hitch] Plenty of mountains at 4k+, WOT for several minutes at a time.) Right bank were only .005 over new plugs (Iridium) going in but Left bank was almont double the gap. The skinny part of the electrode was almost (if not entirely) worn away. Wires, and boots were also NGK and same change interval as plugs. The only codes I had were misfires which occured on damp mornings until the engine warmed up a little. Same codes/issue that prompted the change 60k ago.
I'm curious what would cause such different wear side to side. Is this normal for the wire side of the shared coil or is it a symptom of something else? I'm not exceptionally worried, and am not looking to spark the great plug preference debate, but am curious if anyone else has seen something similar.
‘99 SR5 Auto, V6, 4x4
pdspen is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 08:25 PM #2
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Yes, I have replaced hundreds of 3.4L plugs and this seems to be pretty normal. I have also found the factory plugs to be different types on both banks. Denso on LH side, NGK on RH side.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 12:19 AM #3
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
The difference in plugs between heads is fabled to be based on the factory assembling the heads at the time. Obviously there is little advantage to following this practice today.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 12:45 AM #4
clearock clearock is offline
clearock has a spectacular aura about clearock has a spectacular aura about clearock has a spectacular aura about
Its because of the wasted spark system used
clearock is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 12:59 AM #5
Kinda accurate... cheap plugs will wear faster/inconsistently in a waste spark system.
Waste Spark Ignitions - NGK Spark Plugs
Old 10-17-2022, 08:30 AM #6
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
Good call....
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2010 Mazda MX-5 Touring
2017 Tundra Limited DC 5.7L TRD 4WD
Buckaroo is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 08:59 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Yup wasted spark systems will were put twice as fast as standard spark ignition. So if the plugs are normal use are 100k miles. In the 3rd gen v6 its only 50k.
Old 10-17-2022, 10:00 AM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Recommended factory service interval for dual electrode spark plugs is 30k miles so I would expect to see a lot of wear since you went twice the recommended service interval.
Old 10-17-2022, 08:08 PM #9
Thank you MaineRunna, good to know this sounds normal.
And for the record I don’t think those plugs owed me anything for the mileage they were run, just thought the difference between banks was odd.
Old 10-17-2022, 11:26 PM #10
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Doesn't that assume standard copper plugs though? Platinums should last a little longer.
Sent from my moto g(7) power using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 08:58 AM #11
Real Name: Patrick
Real Name: Patrick
Platinums will last longer, but not twice as long.
Old 10-18-2022, 09:19 AM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
From what I observed @badluck is correct they will not go twice as long then the standard plugs because of the double spark. So if they are supposed to last 100k. They be extremely warn at 50k. Because they did 200k worth of work. If your following what we are trying to explain...
Old 10-18-2022, 11:38 AM #13
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
I have the 6EK-11 double platinums in my Saturn. I’ll tell you what the erosion is like. The regular EK’s wore down .005-.008 in 50k miles.
Old 10-18-2022, 01:35 PM #14
ryandc ryandc is offline
ryandc is on a distinguished road
Wasted spark, as others have mentioned.
Because the plug is making the jump one way in one bank and the other way in the other, you will see the cathode wear more in one bank and the anode wear more in the other. This is typical, and you'll typically see this as the tip wearing a lot more in one bank than the other (doesn't impact ignition in a meaningful fashion).
I ran NGK Iridiums for 100,000 miles - put them in at 190 and replaced them at 290. Didn't look factory new, but damn close, and no issues at all.
Platinums will wear 2x as fast, the replacement interval is ideally going to be 25k-50k.
ryandc is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 01:59 PM #15
Very good point!!!!
60k , bank , plugs , side , spark
spark plug rounded, remove spark plug tubes? Danger Mouse 3rd gen T4Rs 0 05-02-2021 03:43 PM
Spark plug concerns? Normal wear?? zguy1 4th Gen T4Rs 9 12-08-2020 09:27 PM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Rockauto 0 01-12-2017 02:52 PM
Wear on spark plugs pics Aquabear 4th Gen T4Rs 1 03-15-2012 09:06 PM
spark plug gap Armandi Maintenance/Detailing 3 02-06-2005 08:17 PM
