10-16-2022, 07:17 PM
Spark plug wear
Just changed spark plugs on 99 SR5, 5VZ 325,000mi and noticed that the left bank of plugs (wire side) had worn much more than the right bank (coil side).
Plugs were NGK Platinum and had been in the vehicle for a little over 60k of hard miles. (Plenty of towing including 2 cross country trips pulling around 6k. [Proper coolers, air bags and WD hitch] Plenty of mountains at 4k+, WOT for several minutes at a time.) Right bank were only .005 over new plugs (Iridium) going in but Left bank was almont double the gap. The skinny part of the electrode was almost (if not entirely) worn away. Wires, and boots were also NGK and same change interval as plugs. The only codes I had were misfires which occured on damp mornings until the engine warmed up a little. Same codes/issue that prompted the change 60k ago.
I'm curious what would cause such different wear side to side. Is this normal for the wire side of the shared coil or is it a symptom of something else? I'm not exceptionally worried, and am not looking to spark the great plug preference debate, but am curious if anyone else has seen something similar.
‘99 SR5 Auto, V6, 4x4
10-16-2022, 08:25 PM
Yes, I have replaced hundreds of 3.4L plugs and this seems to be pretty normal. I have also found the factory plugs to be different types on both banks. Denso on LH side, NGK on RH side.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
10-17-2022, 12:19 AM
Real Name: C8H18 Mike
The difference in plugs between heads is fabled to be based on the factory assembling the heads at the time. Obviously there is little advantage to following this practice today.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
10-17-2022, 12:45 AM
Its because of the wasted spark system used
10-17-2022, 12:59 AM
Kinda accurate... cheap plugs will wear faster/inconsistently in a waste spark system.
Waste Spark Ignitions - NGK Spark Plugs
10-17-2022, 08:30 AM
Good call....
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
10-17-2022, 10:00 AM
Real Name: Patrick
Real Name: Patrick
Recommended factory service interval for dual electrode spark plugs is 30k miles so I would expect to see a lot of wear since you went twice the recommended service interval.
10-17-2022, 08:08 PM
Thank you MaineRunna, good to know this sounds normal.
And for the record I don’t think those plugs owed me anything for the mileage they were run, just thought the difference between banks was odd.
10-17-2022, 11:26 PM
Doesn't that assume standard copper plugs though? Platinums should last a little longer.
Sent from my moto g(7) power using Tapatalk
1997 SR5, 3.4L, Manual
10-18-2022, 08:58 AM
Real Name: Patrick
Real Name: Patrick
Platinums will last longer, but not twice as long.
10-18-2022, 11:38 AM
I have the 6EK-11 double platinums in my Saturn. I’ll tell you what the erosion is like. The regular EK’s wore down .005-.008 in 50k miles.
10-18-2022, 01:35 PM
Wasted spark, as others have mentioned.
Because the plug is making the jump one way in one bank and the other way in the other, you will see the cathode wear more in one bank and the anode wear more in the other. This is typical, and you'll typically see this as the tip wearing a lot more in one bank than the other (doesn't impact ignition in a meaningful fashion).
I ran NGK Iridiums for 100,000 miles - put them in at 190 and replaced them at 290. Didn't look factory new, but damn close, and no issues at all.
Platinums will wear 2x as fast, the replacement interval is ideally going to be 25k-50k.
10-18-2022, 01:59 PM
Very good point!!!!
