Old 10-20-2022, 11:45 AM #16
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by Twisted Sid View Post
As far as valve shims go, does anyone know if the shims are universal to toyota engines and if not, what Toyota engines use these same shims as the 5vz and 3rz?
I'm thinking the next time I'm at the junkyard, ill start to grab a bunch of shims to have on hand because both my engines are due. For a few dollars, I might just get lucky and get the right thickness I need
Here you go.
Toyota 5vz-fe valve adjustment guide - Google Sheets
That doc is provided in the video description of this video my buddy Wei and I made.
t
Old 10-20-2022, 04:05 PM #17
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
Yes they are universal and used in a wide selection of Toyota engines that were made in the same era. 4 cylinder Toyota engines sometimes do not use shims. They are not simple to remove though so it's a bit of work to get them out, even if you do choose to take out the camshafts. Most shims used from the factory are between 2.80 to 2.95mm in thickness and in the three engines I've torn down for the shims that has been true. You'll still have to special order (or ask for the shim box) any shim at or above 3.00mm as you will have a hard time finding that in a factory engine. I am thinking that is their maximum tolerance from the factory.
And for the love of all things Toyota, please don't use standard measurements! The shims are stamped "280" or "295" on the shim itself so you don't even have to measure them as it's the thickness in millimeters.
Found a list of all engines. I think some of the 4 cylinder engines on this list are incorrect though, I'd stick to 6 cylinder engines:
Valve Shim - Toyota 28mm (1990-2011) OEM Valve Shim
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 240K miles.
326WHP 347TQ
exhaust , gasket , oil , replaced , valve
3rd gen VSV Valves 4racer For Sale: T4R Items 2 09-27-2016 11:25 AM
IAC valves, TPS Dinabox Pimp Zone 15 06-25-2013 12:47 PM
How do these valves look? pablosan Classic T4Rs 0 02-16-2013 09:24 PM
Adjustable tire pressure relief valves? Krazynative Engines / Suspension / Wheels / Tires / Audio / Accessories 10 05-22-2012 07:41 PM
Adjustable vs. Non-Adjustable Shocks G8RB8_12SR5 5th gen T4Rs 4 04-28-2012 12:01 AM
