Originally Posted by T4R2014
I believe you can re-pin the connector to use a 99+ MAF. That being said it is a massive waste of time on a stock 5VZ.
So if you wanted to use the 99+ MAF and got the complete 99+ airbox components in front of the MAF, you would still have to rep-pin the 98 MAF connector plug?
I'm guessing the bolt holes for the airbox/frame connection would be the same, but does anyone know for sure?
I found that Rock Auto carries some that are for the 98 MAF and Amazon as well, but if I can convert over to the 99+ design where they still make OEM MAF's, that seems like the long-term way to go.
