Old 10-18-2022, 07:15 PM #1
NoVA_T4R NoVA_T4R is offline
NoVA_T4R is on a distinguished road
3rd Gen Mass Air Flow Sensor - Turbine version aftermarket results
Hi,
Would like to know if anyone has replaced their 96-98 cylindrical "turbine" MAF sensor with a non-OEM aftermarket sensor? Which brand and have you had any problems with it? What did you ultimately settle on?
Also, if anyone has converted from the turbine to the rectangular version for the 1999+ models, what parts did you have to get?
Thanks.
NoVA_T4R is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 09:40 PM #2
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
I believe you can re-pin the connector to use a 99+ MAF. That being said it is a massive waste of time on a stock 5VZ.
Old 10-19-2022, 05:40 AM #3
So if you wanted to use the 99+ MAF and got the complete 99+ airbox components in front of the MAF, you would still have to rep-pin the 98 MAF connector plug?
I'm guessing the bolt holes for the airbox/frame connection would be the same, but does anyone know for sure?
I found that Rock Auto carries some that are for the 98 MAF and Amazon as well, but if I can convert over to the 99+ design where they still make OEM MAF's, that seems like the long-term way to go.
Old 10-19-2022, 07:14 AM #4
Chuckles89's Avatar
Chuckles89 Chuckles89 is offline
Real Name: Charlie
Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about
Chuckles89's Avatar
Real Name: Charlie
I did the 99+ intake swap on mine. Easy enough. No difference LOL
Originally Posted by STX4Runner View Post
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
Chuckles89 is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 01:24 PM #5
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
The pre 99 maf is very expensive from Toyota so your best bet is to either get one from the junkyard or repin your connector to use the newer and far cheaper 99+ maf. I wouldn’t use anything that isn’t Toyota or denso
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 04:01 PM #6
Chuckles,
When you say no difference, does that mean the connector wires do not require re-pinning? Just a straight swap of everything from the MAF sensor to the airbox?
Old 10-19-2022, 06:48 PM #7
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by NoVA_T4R View Post
Chuckles,
I have been running like this since 2018, no problems whatsoever.
Old 10-20-2022, 07:12 AM #8
Chuckles89's Avatar
Real Name: Charlie
Chuckles89's Avatar
Real Name: Charlie
Chuckles,
No difference in how the engine runs.
You do have to repin the connector which was pretty easy
Old 10-20-2022, 03:57 PM #9
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
If you'd like to do the swap you can find a photo of the repin order in my build thread. It's moving the black wire from the end to the second position and moving the others down one spot.
The main reason why you'd want to switch to the 99+ design is replacement costs. The 96-98 MAF sensor costs almost $300 new. The 99+ one can be found for about $60. If your old turbine style MAF isn't breaking though I don't think it is worth the time and cost. The parts you will need are the airbox and the MAF sensor. The intake can be re-used if my memory serves me right. At a junkyard the airbox is around $50 and the sensor around $30.
If you are supercharged or doing a forced induction conversion then there's other obvious benefits as you open up the intake tube significantly and dramatically increase air flow.
326WHP 347TQ
aftermarket , brand , non-oem , sensor , turbine
Mass Air Flow Sensor White4runner 4th Gen T4Rs 7 07-03-2020 08:16 PM
Mass Air Flow Sensor KNou 3rd gen T4Rs 8 12-27-2012 12:37 AM
Mass Air Flow Sensor MIKEBO Classic T4Rs 2 03-19-2011 02:55 PM
V6 MAF Mass Air Flow Sensor duckyjp 3rd gen T4Rs 3 01-03-2006 01:38 AM
Mass air flow sensor Armandi 3rd gen T4Rs 2 02-03-2005 10:13 AM
