Old 10-19-2022, 04:23 PM #1
psea17 psea17 is offline
psea17 is on a distinguished road
Battery Wiring
seem to be having an issue post big3 where im getting a lot of corrosion on the battery terminals and the wires attached. happening on both pos/neg terminals.
can someone tell me where this wire is supposed to run to?
any other suggestions? im checking resistance on my cables & cleaning all connections (again). also going to find a better location to ground the frame and body to the battery.
Battery Wiring-resized_20221019_131935-jpg
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 06:01 PM #2
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
It’s your battery causing the corrosion. Maintenance free batteries vent out of the posts when the internal valving can’t cope with the gasses.
I conductive grease like No-oxide will keep the acid from corroding the posts and terminals.
Old 10-19-2022, 06:07 PM #3
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
Any number of corrosion inhibitors will help - I have more recently been doing a spray of Fluid Film on my posts. A new/better battery (that vents less) will help.
Is that the one that goes to the ground side of the battery? If so, it routes down and connects to the block next to the oil filter mount.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-19-2022, 06:32 PM #4
thanks guys.
charlie, i think you're right. it was rendered obsolete when i ran 2awg to the same location as part of my big3 upgrade.
Manual Transmission
Old 10-19-2022, 09:51 PM #5
Buy a battery that has cell caps. Interstate is a good example.
Old 10-20-2022, 01:01 AM #6
that"s actually the brand i have.
Manual Transmission
Old 10-20-2022, 12:05 PM #7
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
AGM batteries FTW
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
battery , checking , run , suggestions , terminals
Battery tender wiring NoSoupForYou 5th gen T4Rs 6 08-15-2022 03:34 PM
Too Many Wiring Terminals on Battery Bad? Chilow 5th gen T4Rs 10 07-29-2020 01:26 PM
Help getting wiring from the rear roof rack to the battery. depth 4th Gen T4Rs 2 11-02-2017 05:10 PM
Wiring battery in "aux" position to be starting battery... joneseyyy 5th gen T4Rs 6 06-09-2013 11:10 PM
Need help Wiring to battery bcsan 4th Gen T4Rs 6 10-25-2005 10:59 PM
